Hi there ...... Another newbie to the world of DVD recording has been stumbling blindly amongst scart leads galore and has come up with a problem ..... Bought the recorder before Christmas and have up until this time been backing up VHS. Now, I want to copy a couple of the DVDs that I've already backed up. If you get my drift? I've stuck the plugs in where they should be and can get the 2nd DVD player signal through the EXT 2 channel on the recorder. And it records with no problem, HOWEVER ..... the picture and the recording comes through with a blue hue!! Makes everybody look cold!!
The scarts are all decent quality [£20 each] but the multi scart box thing isn't the best of quality. Would the problem be the multi scart thing? If so I'll change it. [The picture quality is as good pixel wise, just blue] If not what could the problem be please people?
I'm not very technical minded so if I have to follow any instructions, could you make them 'idiot proof' please?
I did actually try and change the RGV setting on the player, but it just turned the picture from blue to black and white.
Anyhoo, hope there's some one out there thats thinking 'I know what her problem is' ......... Many thanx in advance. SEESE[/b]
Blue-Ray DVD Player Philips BDP3100 unlock Subtitles code
By shalevagr in forum Authoring (Blu-ray)Replies: 10Last Post: 19th Jul 2011, 03:50 -
Philips 40PFL7505D/F7 - blue tint in dark areas problem
By micallen in forum DVB / IPTVReplies: 26Last Post: 23rd Feb 2011, 11:30 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
Zoom / Small blue box bottom right corner of screen on Philips DVP-3252
By DVP-32 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 25th Jul 2008, 15:34 -
Philips DVD 642/37 Mostly a Blue Picture
By Shieh in forum Newbie / General discussionsReplies: 3Last Post: 3rd Feb 2008, 12:32
[/b]
