I tried it out ...
When you set up chapter points in TDA ... you can hear audio now.
When you choose the video to play as the image in background for menu ... you can hear the audio ... when previewing.
Yes it will convert videos with LPCM or MPEG audio ... to AC-3 audio.
But ... after TDA has made the DVD Video ... the audio in the menu will still be LPCM.
Hmmm ... Seems I have to create a special video with LPCM audio if I want use a specific background video in the Menu ... or I wont hear any audio in the menu.
Why can't I have AC-3 audio for my menu ... too![]()
Closed Thread
one topic is enough.
https://www.videohelp.com/forum/viewtopic.php?t=200785
if you want to change information just edit your old topic or post a reply.
TMPGenc Xpress 4 and Mpeg Video Wizard DVD VFapi plugin
By stanB in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 15:46 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
