Has anyone been able to get to Paypal in the last day or so?
Results 1 to 11 of 11
I still can't get there. Just tried. Even the guy I bought something from can't get there either....Hmm.
check your hosts file to see if you have been hit by that virus
do a search on your system and see if you have more than 1 hosts file and and open them in notepad ..... there should only be one entry (normally - though you can add more in there yourself)
there should only be one hosts file in the /etc directory"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I read on Ebay's community Bulletin Board that Paypal changed something in their security settings or something. I have everything that the message from Paypal said (IE 6 or higher and 128bit encryption) but still can't get there.
I'm getting REAL sick of these a$$holes. -
Just did a Live Update and ran Norton.....nothing found.Originally Posted by BJ_M
In my experience Norton wouldn't locate a problem like this.
Whenever something messes with my hosts file I find that a scan with Spybot Search and Destroy as well as a sweep of my files by a program called Privacy Outpost will usually solve all problems.
So you might want to give that a go (all programs listed above are shareware I believe) and then see whether you can reach PayPal.
You might also want to a Windows Update to see if you need any updates from their. -
Anyone know how to get XP to start up in Safe Mode? I tried the F8 key repeatedly and (so far) it hasn't worked.
I was attempting to download a Windows Update when I had to cancel it. It was downloading the English version and my computer is HERE is German....OLD habits die HARD.
I need to set it back one day to try to undo the bad update if possible. The computer starts up...Windows "tune" plays...I see my desktop for a brief moment and then the blue screen of death.
Any suggestions?
Thanks guys
hech -
if you cant hit f8 at the right moment (you dont have a big window there to hit it)
put a floppy disk in and change the bios so it boots off the floppy first .. it will stop there and then you can remove floppy and hit f8"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
OK.....I'm on Safe Mode. The "set back"option won't work in Safe Mode though. Hmmmm
PayPal scamers, what can we do about it?
By G)-(OST in forum Off topicReplies: 4Last Post: 8th Aug 2010, 20:32 -
Purchase with Paypal
By DATENSCHUTZ1 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 8th Apr 2010, 03:52 -
10% off eBay purchase using Paypal
By zoobie in forum ComputerReplies: 0Last Post: 28th Oct 2008, 02:31 -
Just registered using paypal....
By jonmck in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 6th Sep 2007, 04:09 -
PayPal Rebate?
By bevills1 in forum ComputerReplies: 13Last Post: 12th May 2007, 00:44
