i used dvd2one last week. v. 1.2 worked fine, know when i try to use it the start button is greyed out, anyone have this happen and know how to fix it? i'm in 10.3.2. ripped the dvd with dvd backup with no problems. i tried selecting 2 other dvd's too and no luck. any thoughts?
pants on, pants off, pants the floor.
Defaultly the button is greyed out
it only appears when you have properly selected your VIDEO_TS folder and when you have chosen all of the min. requirements for that process
once everything is selected it will appear as normal.
I suspect you know this and that there is something else causing the problem
the issue is WHY!
to date i have NEVER had a greyed out button when all things are properly set
i suspect no one else will be able to reply because this seems too wierd
Perhaps you should upgrade to the latest and give that a try
can you think of anythign differnet you have done -
downloaded the newest version, still not working. tried other discs, from other other drives. still won't allow me to select. this sucks.
Where to start? I'm a amateur photographer and I want to start out in video
By James Wright in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jul 2015, 15:12 -
The Start button and the Windows taskbar don't appear on both display
By 1234567 in forum DVB / IPTVReplies: 12Last Post: 2nd Sep 2010, 11:39 -
Program Edit greyed out on NEC NDRV-60
By scottee in forum Newbie / General discussionsReplies: 0Last Post: 6th Jan 2010, 12:25 -
VOB2MPG PRO 3.0.0122 No Audio and No Active Start Button
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 5th Dec 2009, 08:50 -
AutoGK "start" button is greyed out
By Purno in forum Newbie / General discussionsReplies: 3Last Post: 1st Mar 2008, 05:36
