  1. How do I backup a region 2 dvd movie so it can be played in a region 1 dvd player?
  2. Try this:
    Originally Posted by FulciLives
    1.) Rip the DVD with DVD Decrypter in FILE MODE and make sure to SELECT ALL FILES
    2.) Now process with DVDShrink (assuming this is a dual layer DVD)
    Step one removes any and all copy protection including region code stuff.
    - John "FulciLives" Coleman
    P.S.
    You do realize (I hope) that with a single layer original all you need to do is RIP in DVD Decrypter using ISO READ MODE then burn it with DVD Decrypter using ISO WRITE MODE.
    Look here: Region Code 2 tried dvddecry/dvdshrink along with IfoRegion
    By the way, is Fritzov russky?
  3. if your dvd player is multisystem, you should have no problems.
    if its a dvd5;
    rip with dvd decrypter in iso/read mode & then write in iso/write mode
    if its a dvd9;
    rip with dvd decrypter in file mode & then transcode with a varity of programs
    dvd2one
    nero record
    dvd shrink
    clonedvd
    pinaccle instacopy
    there are many to choose from, once you've transcoded just burn the files to a dvdr.. i like recordnow max..
    as long as your dvd player will display a pal dvd on an ntsc tv correctly, you should have no problems.
