Can someone please help me out? Am I doing something wrong? Is it a problem with my media? 5 bad discs out of 23 so far!!?? Below is my .log file for Nero...
Thanks for the help guys.
Matt.
Ritek g04 4x
Pioneer 106D
Nero X-Press
Windows 2000
Log date: Tue Jan 20 19:57:06 2004
Project: UNDEFINED
Using ImgTool Version 1.1.0
Can't open INI file (F:\program files\encoders\ImgTool Burn\ImgTool.ini),
using default settings...
Opening NeroAPI.DLL
Nero API version 6.0.0.15
Initialization of the NeroAPI successful.
Found the following devices:
PIONEER DVD-RW DVR-106D
Image Recorder
Starting Burn Process...
...burn on "PIONEER DVD-RW DVR-106D"
Using ISO Flags: ISO UDF Realloc
Number Of Tracks: 0
try to building DVD ISO Tree...
Start path: "H:\gangs2"
AUDIO_TS dir is not present, try to create one...
VIDEO_TS dir is not present, try to create one...
building VIDEO_TS Tree...
Adding VIDEO_TS.IFO
File: "VIDEO_TS.VOB" doesn't exist ==> create ISO without it!
Adding VIDEO_TS.BUP
Adding VTS_01_0.IFO
Adding VTS_01_1.VOB
Adding VTS_01_2.VOB
Adding VTS_01_3.VOB
Adding VTS_01_4.VOB
Adding VTS_01_5.VOB
Adding VTS_01_0.BUP
Writing on DVD Media...
Using Speed: 4.0x (5540kB/s)
===> DVD-Video files reallocation started
===> DVD-Video files reallocation completed (no file modified)
===> DVD-Video files sorted
=> Reading directories
=> Creating directories
=> Finishing
=> Checking discs
=> Writing to cache
===> Caching of files started
===> Caching of files completed
=> Writing to disc
===> Burn process started at 4x (5,520 KB/s)
=> Writing Lead-in
=> Writing tracks
===> Communication failure
===> Burn process failed at 4x (5,520 KB/s)
Windows 2000 5.0
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 5/6/2002 10:01:14 AM
ahead WinASPI: File 'F:\program files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 6/17/2003 5:25:04 AM
Nero API version: 6.0.0.15
Using interface version: 6.0.0.0
Installed in: F:\program files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Recorder: <PIONEER DVD-RW DVR-106D>Version: 1.07 - HA 1 TA 0 - 6.0.0.15
Adapter driver: <atapi> HA 1
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
DiskPeripheral : ST380021A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : 24X10X40 CD-RW atapi Port 0 ID 1 DMA: Off
CdRomPeripheral : PIONEER DVD-RW DVR-106D atapi Port 1 ID 0 DMA: On
CdRomPeripheral : LITEON DVD-ROM LTD163D atapi Port 1 ID 1 DMA: Off
=== CDRom-Device-Map ===
24X10X40 CD-RW E: CDRom0
PIONEER DVD-RW DVR-106D I: CDRom1
LITEON DVD-ROM LTD163D K: CDRom2
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 360MB (369476kB)
Memory in use : 29
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
20.1.2004
NeroAPI
7:48:56 PM #1 Phase 112 File APIProgress.cpp, Line 238
7:48:56 PM #2 Phase 114 File APIProgress.cpp, Line 238
7:48:56 PM #3 Phase 111 File APIProgress.cpp, Line 238
7:48:56 PM #4 Text 0 File Reader.cpp, Line 118
Reader running
7:48:56 PM #5 Text 0 File Writer.cpp, Line 127
Writer PIONEER DVD-RW DVR-106D running
7:48:56 PM #6 ISO9660GEN -11 File geniso.cpp, Line 3861
First writeable address = 0 (0x00000000)
7:48:56 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3861
7:48:56 PM #8 Text 0 File Burncd.cpp, Line 3169
Turn on Disc-At-Once, using DVD media
7:48:56 PM #9 Text 0 File DlgWaitCD.cpp, Line 230
Last possible write address on media: 2298495 (510:46.45)
Last address to be written: 2210751 (491:16.51)
7:48:56 PM #10 Text 0 File DlgWaitCD.cpp, Line 235
Write in overburning mode: FALSE
7:48:56 PM #11 Text 0 File DlgWaitCD.cpp, Line 1878
Recorder: PIONEER DVD-RW DVR-106D, Media type: DVD-R
Disc Manufacturer: RITEKG - 04
Disc Application Code: 64, Disc Physical Code: 193
7:48:56 PM #12 Text 0 File DlgWaitCD.cpp, Line 393
>>> Protocol of DlgWaitCD activities: <<<
7:48:56 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 769
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2210752 (2210752) = #2210752/491:16.52
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2210752 blocks [PIONEER DVD-RW DVR-106D]
7:48:56 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 938
Prepare recorder [PIONEER DVD-RW DVR-106D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 4527927296, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2210752 | lead-out | 1 | 0x00 | 0x41
7:48:56 PM #15 Phase 24 File APIProgress.cpp, Line 238
7:48:56 PM #16 Phase 25 File APIProgress.cpp, Line 238
7:48:56 PM #17 Phase 36 File APIProgress.cpp, Line 238
7:48:57 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2136
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
7:48:57 PM #19 Text 0 File DVDR.cpp, Line 1479
Recording mode: Sequential Recording Mode
7:48:57 PM #20 Text 0 File Mmc.cpp, Line 19000
Set BUFE: supported -> ON
7:48:57 PM #21 Text 0 File DVDR.cpp, Line 1594
Start write address at LBA 0
DVD high compatibility mode: No
7:48:57 PM #22 Text 0 File Cdrdrv.cpp, Line 7909
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: 10.08 Mbps (2 h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
7:48:58 PM #23 Text 0 File Writer.cpp, Line 318
19:48:58.323 - PIONEER DVD-RW DVR-106D : Queue again later (Intervall : 11msec)
7:55:17 PM #24 SCSI -1024 File Cdrdrv.cpp, Line 1411
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x097A0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x08
Sense Qual: 0x01
CDB Data: 0x2A 0x00 0x00 0x0E 0xB5 0xE0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x04 0x00 0x93 0x00 0x02 0x0E
0x26 0x01 0x30 0xE6 0x08 0x01
7:55:17 PM #25 CDR -1024 File Writer.cpp, Line 335
7:55:17 PM #26 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
7:55:17 PM #27 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
7:55:17 PM #28 Phase 38 File APIProgress.cpp, Line 238
Existing drivers:
File 'Drivers\CDR4_2K.SYS': Ver=2.5 (089), size=52720 bytes, created 3/2/2001 8:55:54 PM
File 'Drivers\CDRALW2K.SYS': Ver=1.00 (1030), size=22585 bytes, created 3/2/2001 8:55:54 PM
File 'Drivers\ASPI32.SYS': Ver=4.71 (0001), size=17005 bytes, created 5/6/2002 10:01:08 AM
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
BurnCD() : burn failed
Logfile saved at: Tue Jan 20 19:57:06 2004
thanks tomp[ika will try it... so in other words its not a media issue is it?? Just wondering so I can try and get some replacements...
Thanks. Matt. -
I did - and still I get the communication error and I am using a new pack of dvd-r's from a different distribution company.. same brand.. Ritek G04..Originally Posted by tompika
anyone out there that has resolved this problem??
(1) Burn failed !!
By skinney6 in forum DVD RippingReplies: 13Last Post: 4th Feb 2010, 18:01 -
DVDfab failed initializing burn engine
By etlund99 in forum ComputerReplies: 0Last Post: 29th Jul 2009, 13:19 -
Seek Failed
By zeke1312 in forum Video ConversionReplies: 1Last Post: 20th Mar 2008, 06:59 -
New DVD writer... Burn process failed at 2x (2,770 KB/s)
By planetx in forum DVD & Blu-ray WritersReplies: 8Last Post: 8th Feb 2008, 15:40 -
mkv failed @ 90%
By joshmunkey in forum ffmpegX general discussionReplies: 2Last Post: 7th Nov 2007, 18:53
