hey all i have a duron 750 and wanna upgrade just my cpu do u know how high i can go?
is there a 1.8 duron?
anyone know?
heh. duron..
it depends on your motherboard. look in the manual or look it up online to see what options you have as far as upgrading your cpu -
i dont have a book i bought this system 3 yrs ago for 999! killer deal than
Unless it is an OEM, with no POST screen, copy down the long line of characters at the bottom of the first screen, go to www.motherboardhomeworld.com , enter the numbers they tell you they need, and you will find all you need about maker and the like. Manual will be available at the site you are handed off to.
It will tell you what the board will go up to. It may actually go that high, at least it may after a BIOS flash. And it does not have to be a Duron. Any socket that would take a Duron will take an Athlon.
be warned, you might have to 3 finger salute it a few times to copy all the characters, if your pause or control keys don't freeze the screen.
Cheers,
george -
hey george that website doesnt even work for me and the numbers are on my motherboard?
Creating DVD with stills, need advice on upping the quality.
By RebeccaDesigns in forum MacReplies: 6Last Post: 4th Aug 2011, 10:29 -
New CPU
By Sckinhunter in forum ComputerReplies: 9Last Post: 13th Apr 2011, 01:10 -
CPU
By HotDamn! in forum ComputerReplies: 7Last Post: 17th Dec 2009, 01:21 -
CPU Temperatures Going Up
By wulf109 in forum ComputerReplies: 2Last Post: 8th Mar 2009, 13:45 -
CPU-Z reading for Intel Allendale cpu
By budz in forum ComputerReplies: 11Last Post: 8th Jul 2007, 19:33
