http://www.cooldrives.com/firewireinfo.html
If you purchased your drive before October 31 from Cooldrives/FirewireGear/FirewireMAX/FirewireDirect/GraniteDigital/FWDepot/WiebeTech or anywhere else, unless you are 100% certain the Oxford firmware has been updated to v. 1.05, do not use any FireWire 800 storage products with Macintosh OS X 10.3. It can result in a catastrophic loss of data.
Unlike Elsewhere, Most of our customers did not get affected by this Oxford 922 problem
as we utilize a NEWER/FASTER and BETTER INITIO Chip in most of our Enclosures!
MAC INTIO 2430 FIRWARE UPLOADER
Windows INTIO 2430 FIRWARE UPLOADER
Firmware for Multi-Bay Enclosures (each board must be Flashed individually) Ver. 2.16
Dear Customer,
Recently there has been some reports that FireWire 800 drives based on Oxford Semiconductor's 922 chip may malfunction under OS X 10.3/Panther operating system. Exact nature of the problem has not been clearly identified. We do know that it does not affect every FireWire 800 drive/enclosure, nor every Panther machine. Up until this moment, no one, including Oxford Semiconductors and Apple Computers, has been able to reproduce this problem consistently.
In conferring with Oxford Semiconductors, it is advisable that all 922-based FireWire 800 drives be shipped with the latest firmware available. Currently, that means v. 1.05. According to Oxford Semiconductors, this should prevent the problem from occurring.
To solve the problem, we recommend following steps: Backup all your data now! Upgrade the firmware of your Macpower Product (Oxford 922 chipset only) Always disconnect the external hard drive before shut down/start up of Mac OS 10.3 Only connect the external drive after the system has booted up Do not connect any external drives when installing the new OS 10.3 Check for OS upgrades frequently Firmware Upgrade
To see what firmware version is used on your device and to upload the latest version, we have prepared an updater utility for Mac and PC. A few points before downloading this utility:
Upgrade has to be done via Firewire, 1394a (9-6pin cable) or 1394b (Firewire 800) connections are both OK. Hard Drive does not have to be connected, bridge board and power supply is sufficient for the firmware upgrade. If you already have v1.04 and everything works as expected but you wonder if you should upgrade to v1.05 or not, we recommend not to change anything, therefore preventing any problems which could be caused by an upgrade or a void warranty. Follow the installation instructions on the Readme file after you have downloaded the file below.
If you have a MACPOWER ICE OXFORD 922 ENCLOSURE Mac OS 10.2.8 --> '922_updater_Mac.sit' PC WinXP --> '922_updater_PC.zip'
IF YOU HAVE A BLACK ICE OXFORD 922 ENCLOSURE PLEASE GET THESE FILESOX922 UTILITY for NEWMOTION
UTILITY UPDATE TUTORIAL
correct me if I am wrong.. but its already been covered
While I have enothing to add to the Firewire 800 saga (my dual G4 has firewire 400), I will toss this tip out there for who ever might need it.
Yesterday I assembled an external Firewire drive (A Seagate 200G drive I got at CompUSA for $100 after rebate, and a $40 external case). I thought I knew what I was doing when I set the jumper on the drive to "Cable Select" (the three internal drives I added to the G4 worked fine with that jumper setting).
The drive appeared on the desktop; I used Disk Utility to format it; tried copying a test file to it and my system locked up. After poking around on the net for a while I discovered that external firewire drives need to be set to "Master." Once I switched the jumper, everthing was good. I also upgraded the Oxford Bridge firmware to the most current version. Panther is purring...
william -
Just to add...If drive is not set as "master" the speed of transfer decrese by half...
Not quite sure why this is being posted on this site now ... this is OLD news and has been covered extensively on every Mac website in existence :P
http://www.macnn.com/news/21890
News report on this issue dated 4th November 2003...
Sorry if already posted : Question about BD and DVD's ....
By tcory in forum MediaReplies: 6Last Post: 24th Feb 2011, 16:11 -
Issues with my web browser
By alintatoc in forum ComputerReplies: 9Last Post: 23rd Sep 2009, 03:27 -
Firewire static issues
By Tenderman in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2008, 02:33 -
Sync issues with encoding for DVD or Web
By sfischer in forum MacReplies: 2Last Post: 26th Dec 2007, 20:01 -
sorry if this has been posted
By bams68 in forum Newbie / General discussionsReplies: 3Last Post: 9th May 2007, 22:22
