Is there a device out there thats made to be small, portable, and that has RCA or Coaxial in ports for the sole purpose of recording/capturing video? I want to get a helmet cam for my Mountain Biking but the camera requires a device to record what its seeing; and a camcorder is to big/expensive for me. Thanks.
Premier DV-2000 Solid State MPEG4 Digital Camcorder -- its small enough to use AS your helemet cam (and its cheap)
it looks like almost the same thing but this one has a av input also
Pretec's DV-4200 http://www.pretec.com/index2/product/digital_imaging/DV4200.htm"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Looking for a portable dvd Player or similar device.
By AntCoe in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Oct 2011, 16:54 -
Capture Device
By NMeade in forum Capturing and VCRReplies: 7Last Post: 24th Feb 2011, 18:23 -
Need recommendation for portable device.
By therock003 in forum Portable VideoReplies: 8Last Post: 20th Apr 2009, 13:59 -
Slightly OT -- Power Supply for External USB HDD used with Portable Device
By GrayStrickland in forum Portable VideoReplies: 2Last Post: 25th Mar 2009, 15:50 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31
