Hi, I capture eps of a tv show which are an hour long but after I edit it and join all my files together my 43 m eps are about 400MB I am just wondering if there is a way I can make the files smaller?
I capturing with a tv tuner card
use virtual dub to edit out the commericals and make it clearer, then I convert each seperate file to mpg with tmpgenc then i join them all together and half an hour shows go about 220 and 43 min ones go 440
is there a way to make them smaller? please is there a way because i am like the savior for this show it moved to another network and i am trying to get as many fans to dl it because this network not many ppl have
thank you
paul
Results 1 to 1 of 1
Re-encode files to make them smaller.
By Benhermies in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2008, 20:27 -
How to make vob files smaller
By aruwin in forum Video ConversionReplies: 2Last Post: 26th Jul 2008, 16:25 -
How do I make a AVI Smaller?
By gottiman in forum Newbie / General discussionsReplies: 2Last Post: 2nd Dec 2007, 05:35 -
how do i make a file smaller?
By Sanosen in forum Newbie / General discussionsReplies: 5Last Post: 28th Sep 2007, 23:57 -
How to make an audio file smaller?
By aruwin in forum AudioReplies: 13Last Post: 29th Jun 2007, 23:01
