is there a way to turn my computer DVD writer into a recorder for television programs? i know i could capture the video and record but i was wondering if there is software out there that allows a direct recording from the broadcast to the DVD.
Results 1 to 10 of 10
No tool can capture directly to the dvd. They all store it on the hd and then burns.
(I first read the subject as "Can a DVD writer become a moderator"....
I have a WinFast tv2000 deluxe tuner/capture card that has a default templete to do this. requires rw disk and worked in the 1 test that I did. When I ended the cap, it came up with some screens about finalizing disc, etc. but it did work. Was just curious to try. Light on burner was flickering during capture, so assume it was direct.
Balrick,
With the proper firmware, it might, don't you think?
3 responses, absolutely necessary, "You are in violation...", , "I see nothing wrong..." (I like this one best, shows they're human.), "Let's give him the benefit of the doubt."
I've said it before, you have a good staff.
Cheers,
George -
ROFL!!Originally Posted by Baldrick
"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole." -
Actually I think the MyDVD 4 and above will record to DVD while watching.. I have tried it, it works well, but I wouldn't use this method from the computer, way to many other options.
Install one in the server and see what happens
Sure, showshifter.com
There is another one I forgot what its called, they did a partnership with clicktv.com where you can get free listings.
how to copy from DVD recorder to external disk or blue-ray writer?
By uwacm@gmx.de in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2011, 06:14 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 03:05 -
Panasonic dmr-e85h recorder/writer player
By BIFFtheSTIFF in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Feb 2008, 23:33 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 05:54 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 22:19
