Just bought Pinnacle's "Studio Gold" but like so many shops,they have the
"practice" that they put an empty box on the shelf, and put at the register,
the stuff in it... but i'm now in doubt, did they put it all in ?
It's Studio 8, plus extra software : HolywoodFX Pro & a "package" that has
20 motion-menu templates.... HolywoodFX Pro comes in a DVD-box,
there are 2 discs marked "Studio (version) 8 [Programs & Content]
and one disc marked "Media Mixers" so i've got a total of 4 discs,
in this big box, So, my question is, is this correct ?
Thanks,
Yodel -
personally, I'd take it back pronto and demand a replacement package still factory sealed.
Outside the fact that you don't have the box in order to see what the outside info says about what's supposed to be inside... the stuff they gave you could be used, earlier versions, returns, whatever.
And there's often an UPC code or similar on the box needed for promos, support, etc. .... -
Do you have also Studio Gold ? how many discs where in it ?Originally Posted by rcbThanks,
Yodel
AVCHD/"Blu-ray" fails to play on Sony X Box. Should it?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 9Last Post: 24th Aug 2010, 18:34 -
DVD+R Gold vs. "Gold"?
By buddycat in forum MediaReplies: 15Last Post: 21st May 2010, 06:22 -
how does one create a "blocked white" quote box in forum posts?
By PosRole in forum FeedbackReplies: 11Last Post: 24th May 2009, 03:46 -
Problem with "Application Support" folder contents (& .flv co
By Fostermeister in forum ffmpegX general discussionReplies: 2Last Post: 12th Dec 2008, 13:59 -
Need info on gold "long-life" DVDs
By Djinn252 in forum MediaReplies: 24Last Post: 12th Oct 2007, 16:11
