Ok I am going to be using a WinTV Theater for my captures. Which OS should I use? Win2k pro or Win98SE. Also should I format my HD as Fat32 or NTFS?
Win2000 with NTFS if go with Win98SE then you limet 2GB or 4GB files size but that depend on the App you use.
hmm...so what app exactly could you use if you were using WIndows 9x/Me to avoid that 4 gig limit on Fat32?
David -
AVI_IO and VirtualDub can both capture to multi-segment AVI files.
Regards.
Michael Tam
w: Morsels of Evidence -
I had win2k with NTFS, just wondering if I capture 1 big file 9GB or multi segment 2GB each for AVI file then I convert to mpeg file which way shows better result. Thanks
Best software to re-format NTFS 2TB HDD to FAT32?
By jbitakis in forum ComputerReplies: 26Last Post: 29th Dec 2012, 17:59 -
Converting External HD's from NTFS to Fat32
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 10Last Post: 30th Oct 2010, 14:04 -
External HDD: FAT32 vs NTFS?
By videobread in forum ComputerReplies: 12Last Post: 28th Jul 2008, 17:09 -
For backup, NTFS or FAT32?
By coody in forum DVD RippingReplies: 16Last Post: 1st Oct 2007, 10:30 -
HDD problem NTFS vs FAT32
By edsmith77 in forum ComputerReplies: 4Last Post: 21st May 2007, 12:17
