I've given up on TMPGEnc. It hates me. What else i can trial or purcahse that can convert xvids to mpegs. ???
Results 1 to 9 of 9
I just used Tmpgenc to encode a small xvid encoded AVI clip I had. It worked fine. Which means that Tmpgenc can process xvid files.
There are tons of threads by people unable to open this or that AVI file with Tmpgenc or another program.
It comes down to two things in general:
1. codecs have been messed up and the program doesn't know what to use,
2. Specifically with Tmpgenc, the VFAPI plugin priority sequence was changed and the appropriate codec wasn't used.
I would Start Tmpgenc, go to Options-->Environmental Setting and to the VFAPI plug-in and right-click on the list selecting "Reset to recommended Setting" first. That might just work if you have altered the sequence. Read some of the relevant threads also.The more I learn, the more I come to realize how little it is I know. -
Ok. i'll do that. How long do you think you will be on the board? if you are still on? or anyone else who is on that has the slightest clue what i am supposed to do to make xvid to mpg work.
TMPGEnc does XviD's jsut fine. Your problem is either:
1) Corrupt AVI
2) Bad Codec.
It's #2, bad codec. XviD is several ways to render by itself, much less confusing the issue with FFDSHow. Rebbot/uninstall XviD/Reboot/Install latest version of XviD; this usually fixes the issue. Also, try using the 4cc changer and chaning the headers to divx/divx. This works for me 80% of the time. The other 20% I frameserve from VDUB. Never meet an XviD I couldn't convert (and I capture a lot of TV shows to XviD for my kids, over 2000 hours of cartoons to date).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Hi take a look at my thread. You might get something out of it.
Going nuts with my first Xvid to DVD convertion HELP HELP
Best of luck !!!!
NICE. I fixed it. All i did was uninstall it and installed it again. You might want to put that in the guide for stupid people like me.(i guess somehow along time ago i messed with the options).
Also is there a way that i can choose which type of mpg to make? I am trying to convert it for use in impression pro. Impression didn't take the mpeg that it converted it to. It only takes .... mpv. m2v, mp2 (mpeg2s) or mpv, m1v, mp1(mpeg1's. -
Ok. Do you know which one would acutlaly haev one of those formats? I don't have time to search for it today although tomorrow i'll find out if no one posted back.
Convert avi in xvid to mpeg with subtitle
By mrweisslee in forum Newbie / General discussionsReplies: 2Last Post: 16th Jun 2009, 02:46 -
convert 2cd Xvid to 1cd xvid Avi
By mehargags in forum Video ConversionReplies: 6Last Post: 14th Apr 2008, 10:55 -
What is are some good mac programs that convert AVI to H.264
By VidHunter in forum MacReplies: 5Last Post: 18th Jan 2008, 06:17 -
What programs convert a DVD from/to PAL/NTSC?
By Des in forum Video ConversionReplies: 10Last Post: 14th Nov 2007, 10:00 -
Convert mpeg-2 to xvid while cutting commercials...
By swishbish33 in forum Video ConversionReplies: 5Last Post: 25th Oct 2007, 18:10
