i usually encode audio intoa WAV file, usually my downloads are 2 channel audio compressed with MPEG.
i have just downloaded a film with 5 channels with unknown compression (tag 2000). therefore i cannot encode audio or encode the film through TMPGenc.
is there anything i can do?
tag 2000 is AC3 if I'm thinking correctly. Use VirtualDubMod to save out the waves then use headache to fix them (not the correct terminology but that's what it does.) Encode, wash rinse repeat.
or install the ac3 acm decompressor and you can save to wav directly from virtualdub.
Unable to encode whole video
By Egotomb in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 14:57 -
VirtualDub unable to open avisyth scripts
By suroit in forum EditingReplies: 17Last Post: 19th Dec 2010, 15:13 -
virtualdub won't encode anything
By johnr283 in forum EditingReplies: 5Last Post: 17th Sep 2009, 20:33 -
Automating a VirtualDub encode (Avisynth?)
By crackerbear in forum Video ConversionReplies: 0Last Post: 12th Nov 2007, 15:39 -
VirtualDub unable to keep audio sync'd on *source* audio
By falconne in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 06:12
