I have a Sony DVP-S360. I just recently tried to use it with my Sony surround reciever.
I can't get a Dobly Digital signal with either Digital Coaxile or Fiber Optic. I just get a 2 channel PCM signal. I'm testing with Star Wars Episode II and Mission Impossible, and I know my reviever's good because i get Dolby Digital from my XBOX (optical) and my digital cable (coaxile).
Any help would be greatly appreciated.
Isn't there some sort of sound options menu for that dvd player where you have to specify your output type?
Check that out. -
yup, seabrick is right. usually there is a menu on your dvd player where you can select what type of audio you want to go out. stereo/digital/all ... just select all (if its there) and you should be fine.
yeah, that's what i thought, but i cant seem to find such a menu
i can get the blue menu (its like a bios screen) but its only for correcting errors like disk read and such.
i cant find the way to turn on dolby digital -
oh nevermind, i just found the regular settings menu
everything;s ok now
thanx for your help
Dolby Digital 5.1 -> PC input?
By Asterra in forum AudioReplies: 1Last Post: 4th Oct 2011, 01:38 -
Dolby Pro Logic vs Dolby Digital?
By therock003 in forum AudioReplies: 17Last Post: 11th Jun 2011, 20:51 -
Dolby Digital 5.1-ch vs. Dolby Digital 2-ch
By coody in forum DVD RippingReplies: 6Last Post: 21st Jun 2008, 16:35 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 20:54 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 17:54
