Im encoding a PAL MPEG II file with TMGEnc to burn to a DVD. I select the resolution 720x576 but when i play the DVD back after burning the resoltion is larger than the television and wont fit on the screen. What am i doing wrong? any idea??
thanks
What resolution is your source file? You might need to change the arrange method.
How much of the video are you losing on your TV?
Is all thevideo displayed correctly when you play the mpeg on your PC?
It sounds like it might simply be overscan.
Combine Mpeg-2 Files (without re-encoding or loss of quality)
By Anonymous642 in forum Newbie / General discussionsReplies: 2Last Post: 26th Oct 2011, 06:58 -
RipBot Encoding Wrong Language
By andy6590 in forum Blu-ray RippingReplies: 7Last Post: 1st Apr 2011, 15:20 -
join mpeg files without re encoding
By akakiami in forum Video ConversionReplies: 5Last Post: 12th Nov 2008, 01:18 -
can't join simillar mpeg-1 files without re-encoding
By sohaibrazzaq in forum EditingReplies: 3Last Post: 26th Jan 2008, 08:09 -
Help in making MPEG-2 files smaller with encoding
By screwed in forum Video ConversionReplies: 4Last Post: 20th Jul 2007, 03:23
