I try to burn a dvd video with nero. When I click burn it says the blank DVD is a CDR. I have 3 different brands of DVD and it says the same thing with each one. Can anyone help me please?
Thank-you
Results 1 to 9 of 9
Try flashing your DVD burner with the latest firmware from the manufacturer also, since it contains the media codes.
I suggest you look at the top left hand of the panel and change it to DVD!!.
I am running the demo version of Nero 6 as well as a Pioneer DVR-104 in my compaq. I have tried to download some firmware but it will not install. Any suggestions?????????
thanks -
Make sure you select DVD, on the top left corner. There should be a dropdown box which allows you to select between CD, DVD, etc.
Ur pioneer also might enjoy having pxengine which makes them work better & its a free download at pioneer.com I think, its just yours is so old so .,
I had a similar problem with my Memorex DVD burner and Nero 5. Nero does not recognize the burner until i upgrade to Nero 6 and the problem was solved.
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 21:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 05:06
