I have been using Premiere 6.5 for some time and used Pinnacle Tools for capturing. I export the timeline to MPEG using either the Pinnacle encoder or the Adobe encoder. I have also used the Ligos LSX encoder.
I then used DVDit Pro to make the DVD. It has worked.....until recently. Now when I try to add a video, including ones that I have previously used, I get an error message "unable to find suitable video decoder" and it does not add the file.
What does that mean? I reinstalled DirectX9, and checked the video codecs list. It is a long list ( about a dozen and more items) which includes Morgan Multimedia, Pinnacle, and others.
I can double click the M2V file and use windows media manager and it plays just fine.
What happened? What is missing? what do I need to do?
I should say that I also have my C drive on a mobile dock and I made a new C drive for editing only, starting from scratch, and it does the same thing. Both are using Windows XP Pro. What am I missing?
I too am having this problem with MPEG-2 files I created with TMPGEnc.
Only started after I updated XP and upgraded on Microsoft's web site to Media Player 9. Must have something to do with it!HP Pavilion 1.8Ghz P4 640MB XP Home
2 - 120GB 7,200rpm HD
DVD200i DVD+RW
TMPGEnc,Studio 7, DVDit PE
DVD Decrypter: Unable to find VIDEO_TS folder
By sooojaded in forum DVD RippingReplies: 4Last Post: 9th Sep 2011, 19:51 -
Unable to decompress your camera's image format cause a suitable codec is m
By cfairon in forum MacReplies: 2Last Post: 17th Jan 2011, 10:37 -
Unable to find ASF signature
By hartbarron in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2010, 07:26 -
Who manufacters the AG RW-008? Unable to find a manual online
By ricardouk in forum DVD & Blu-ray RecordersReplies: 0Last Post: 3rd May 2010, 13:36 -
Intensity Pro - Looking for a more suitable Hard drive
By sonico67 in forum Capturing and VCRReplies: 2Last Post: 13th Dec 2009, 19:51
