I saw an ad at Officemax for an 8x burner by KHypermedia.
It claims to be 8x +R (not both???), and it acts all confused (the ad, and their site) as to whether it does 8x write or 8x rewrite (i'm guessing it's 8x4x8, not 4x8x8!).
Also their site has NO firmware downloads, although it does let you log in as a "registered owner", so one would hope there is firmware there.
Does this drive totally suck donkey kong?
- Gurm
Results 1 to 10 of 10
It is a Cyberdrive DX082D and you can get firmware upgrades from them. It is 8X +R 4X +RW 12X read. It is a + only drive, but it seems to do + very well for me. I did just buy it this past weekend so I have not tested a wide range different media. I did use some Imation 4X +r Ricoh's that wrote is 8:04, pretty quick! We also tried some HP 2.4X and Imation 2.4X and they worked fine also.
the officemax i went to had a lot of them in stock. it is 8x write and 4x rw, has a large 8M buffer, seamless link burnproofing, made in china, and for $69 after rebate might be a good deal for someone.saw an ad at Officemax for an 8x burner by KHypermedia.
who does Cyberdrive use as oem suppliers? BTC?Cyberdrive DX082D -
anyone know their website (for firmware downloads)? thanks.Cyberdrive engineer's it's own drives.
Does this drive change the booktype from +R to DVD-ROM like HP 400i and 400e?
The websie is www.cyberdrive.com.tw and yes it does set the booktype to dvd-rom for all disks.
I believe some of the Khypermedia drives are Benq DW800A. I believe someone found out if it says made in Malaysia on the side its a Benq.
What are the differences in these 2 BR Burners?
By golfnut in forum DVD & Blu-ray WritersReplies: 27Last Post: 23rd Apr 2012, 19:14 -
How to Record using 3 External Burners plus 2 Internal Burners with Speed
By mn072065 in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th May 2011, 19:27 -
Kingston Unveils 128GB DataTraveler USB Flash Drive
By G)-(OST in forum Latest Video NewsReplies: 15Last Post: 22nd Jun 2009, 10:27 -
Blue Ray burners for PCs Are they any good?
By bryankendall in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2008, 12:53 -
HD DVD Burners
By leebo in forum DVD & Blu-ray WritersReplies: 5Last Post: 22nd Feb 2008, 22:53
