  1. to mpeg2.
    i keep getting these messages which dont mess up my encoding but only hault it intill I press ok, very fustrating since I can only encode when Im actually on the pc becuase I need to be there to press ok.
    Cinema Craft Encoder SP
    fexp_close() failed:***Could not close this file <C:\programfiles\DVD\SVCD\movie\encoded_video_CCE_ NTSC.mpv>*** The handle is invalid.
    [windows error code 0x6 6]
    I keep getting that error, i press OK and it carries on and the video is fine.
    I thought id update XP with teh windows updates since ive never got any just to see if ti was a windows problem.
    I updated and now my encoding is like twice maybe 3 times as fast and the speeds for frames are much higher than before i dont know why this is but a 28min tv episode used to take over an hour for the video alone, now its about 30mins.
    As well as the error above Im getting this error a couple of times on a encode, very annoying and again haults the process intill i press OK to start it again:
    Cinema Craft encoder sp
    cce encoding failed: error: video check sum is different from that of previous pass. source video data or time code may be different. please check video tape or teh information file.
    ---information---
    current: check sum - 0049a4ca
    previous check sum = 012dd721
    I ahvent tested video done with this error yet but teh encoding just carries on.
    any body help me?
  2. Originally Posted by DTUK
    I have gotten this myself.
    You are not alone.
    Don't give in to DVD2ONE, that leads to the dark side.
