Hi all. I'm new to the digital video scene and I've already learned a lot from reading the forums and guides here, so I hope this hasn't already been covered.
I'm using TMPGEnc to encode digital video captured from my DV camera. From what I've read TMPGEnc is supposed to support DV1 and DV2, but I've found if I don't convert to DV2 then it's like someone has their finger on my audio track in the encoded mpeg (it drags along with the video). Converting to DV2 before encoding yields great results. I haven't tried extracing the audio using VDub and feeding it to TMPGEnc yet (mostly because I haven't taken the time to download and install a VFW codec required by VDub).
Now the obvious answer is "just always covert to DV2 and keep moving"but I'd rather save this step if possible - it takes a while to convert 5GB of video plus I now need twice the hard drive space because I have to create a DV2 file.
By the way, I tried using the freebie NeroVision that came with my DV cam to burn a VCD of the same video and got the exact same "finger on the audio track" results.
Any other ideas? Thanks!
dunno about the various freeware capturing apps, but ScenalyzerLive (shareware) will let you capture type 2 directly from your DV camera, cutting out the converting step...
Thanks for the tips.
bugster, I didn't notice that tool. Nice! I'll try it. I've been using Ulead's VideoStudio that came with the camera. It's a nice capture utility but the version I have only captures DV1.
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 22:22 -
AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
By arcooke in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2010, 14:18 -
Replacing audio in MKV file without re-encoding?
By 3560freak in forum Video ConversionReplies: 4Last Post: 2nd Mar 2009, 22:23 -
audio encoding: tmgenc dvd author 3 vs. tmpgenc plus
By cL0N31 in forum Newbie / General discussionsReplies: 0Last Post: 6th Jan 2009, 23:25 -
Advice Request regarding TMPGEnc, File encoding, and DVD creation w/ Menus
By Hal05154 in forum Newbie / General discussionsReplies: 9Last Post: 25th Sep 2007, 13:13
