Sorry.
Using the wizard for VCD and press the Video button to open the DV2 file, no file is shown. If I click show all files and try to open the DV2 file I get 'This file type is not supported.' type message.
Thanks -
I don't know if things should normally work this way, but when i was having problems with TMPGEnc recognizing .d2v files, the first thing I did was try to adjust the VFAPI settings. When that didn't work, I unzipped/installed (whichever it was) DVD2AVI right into the TMPGEnc folder and viola! It all worked.
May be worth a try in your case... -
Did you install the "VFAPI Reader Codec 1.05"?
You are aware that you need to install the VFAPI codec before the VFAPI-applications can communicate with their plugins?
It's here:
https://www.videohelp.com/tools?tool=139#comments
problems going from quicktime mac file to usable pc file
By pjcom in forum Video ConversionReplies: 11Last Post: 19th Apr 2010, 13:49 -
DV1 versus DV2
By SCDVD in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 23rd Feb 2009, 04:18 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
Pinnacle AV/DV2 or DC10+B miserable performance
By cybertheque in forum Capturing and VCRReplies: 1Last Post: 17th Sep 2008, 21:44 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37
