Hello,
I'm hoping someone can help me out. I have searched this site and the web and found some info but I'm new at this and getting confused on what I should and how i should do this. I'm hoping someone can explain it in easier terms.
I have an avi that is 574x244 23.9 which has an aspect ratio of 2.35. I use TEMPEGenc to make and svcd using the wizard and picking NTSC Film with most of the defaults except for full screen keep aspect ratio and high quality. When I watch it on the tv it looks great except it is so small. I know that cause it has an 2.35 aspect ratio. I tried changing the settings on my tv to 16.9 from 4.3 and it makes it even small. Is there a way I can change it have an aspect ratio of 16.9 so that it is a little bigger on my tv? I want to make the black bars across the top and bottom a little smaller and still keep the right aspect ratio. I don't want to use the no boarders/margins setting cause you lose to much off the sides. I hope I explained what I'm looking to do.
Thanks for any help.![]()
Please Help!!!! You wonderful folks on this site have help me so much in the past with your guides and information. I know somebody has to know this.
No, you can NOT keep the aspect ratio and remove the black borders. You can make it 16:9 but you must cut it then:
Under Settings->Advanced in TMPGEnc select
1:1
full screen(keep aspect ratio)
click Clip frame and cut the left and right so you get it to 16:9(1.7777)
574x244 would be 433x244(size after clipping) = cut 70 pixels left and right. -
Thank you very much for your help. I will try that. Since aspect ratios still confuse me a bit. Could you tell me how you got the numbers 433x244.
Thanks -
Hello,
Just checking to see if I'm doing it right. From what Baldrick wrote and lots of time on the calculator and re-reading all the great info available, I think I have finally figured out how it all works.
To get the new aspect ratio on an avi. The avi file I have is 576x240 unlike what I said in my original post 574x244 was incorrect, sorry. Here is what I did.
240x1.77=424.8 round to 426
426/240=1.775 aspect ratio (what I want)
576-426=150/2=75 round to 76.
clipping 76 pixels from right and left. so the new 426x240=1.77 (16:9)
I think this is right but not sure??? Still learning!!!!
Thanks for readin my post and helping me. -
SVCD only supports 4:3 DAR (Display Aspect Ratio). What you are shooting for is a 16:9 (after clipping) video with black borders to make it 4:3.
You math is correct. Now encode it to add borders as 4:3 and your done!To Be, Or, Not To Be, That, Is The Gazorgan Plan
Encoding .Avi to Svcd?
By mrjust in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2011, 13:40 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 11:41 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 20:25 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
