ok i got a 700 mb avi file that the pixels in it are combineing and the quality is good but for some reason when your watching it the video combines itself with the next scene before the last picture leaving...so while watching it you basically see what you just saw plus the next part at once...and when the last scene starts to fade out it turns into little pizxel blocks and slowly dissapeaqars one by one...is there a way to gte this video fixed so i can turn it into a viewable file?now i have tmpgenc and virtualdub..i will use any tool just tell me where to download it..thank you...i inclued a pic of what i was talkign about
In what media player are you viewing this file? I have had a similar problem with some DivX encoded files when using MS Windows Media Player 8/9. When I use the Divx Player or Media Player Classic, I don't experience this.
Just my experience.
There are a few things I can think of you can do to try and "fix" the file (there're probably others who will expand on this list):
1. Try a different media player.
2. Check for bad frames with VirtualDubMod and fix if any found.
3. Re-encode the file using VirtualDub and a newer DivX codec (5.05 or 5.1x). Note: This will cause some loss of video quality.
4. Convert the file to .mpg. Note: This may cause some loss of video quality.
Use the guides to the left for further information and instructions on 2, 3 and 4 if number 1 doesn't work for you.
Good luck!!
Need help improving the quality of this anime
By Luminous69 in forum RestorationReplies: 11Last Post: 17th Jun 2011, 19:00 -
Improving quality?
By BwanaP in forum Video ConversionReplies: 30Last Post: 19th Jan 2010, 22:03 -
Improving video quality
By rusting in forum Newbie / General discussionsReplies: 10Last Post: 10th Jun 2009, 00:35 -
Improving Video Quality
By pctech@apc4me.net in forum Newbie / General discussionsReplies: 2Last Post: 30th Mar 2009, 18:39 -
Improving quality of mpeg before converting to dvd...
By AshleyQuick in forum Newbie / General discussionsReplies: 4Last Post: 28th Apr 2008, 14:41
