I have a question regarding the burning of a VCD. Suppose you download a VCD that is in the .bin format, does it make a difference if you burn the .bin file directly or if you extract the .bin file (using something like ISObuster) and then simply do a regular burn using the files and folders that were extracted?
The reason why i am asking is when i download a game that is .bin, I HAVE to burn the .bin file and NOT extract it first. The reason is cuz when I burn the .bin file straight, it makes it so the cd is readable. Not sure exactly how to explain but all i know is that when I extract the files first and then burn, the burn and the installation of the game go successfully, but when I go to play the game, it can't read the cd.
I just wanted to know if the same principles apply for movies.
Thanx
same sort of deal here...
you need the directory structure intact... or the vcd will not play in the DVD player... if you want to extract the movie out of the BIN use the VCDgear utility and you can extract the .DAT file out of the bin then convert it to MPG then you can reburn it in NERO if you want...
DVDFlick burning question
By videodude1966 in forum Authoring (DVD)Replies: 6Last Post: 8th Nov 2009, 14:08 -
Question on burning CD
By tee jay in forum MacReplies: 2Last Post: 9th Oct 2008, 01:27 -
Burning question about Studio 10
By jimlong in forum Authoring (DVD)Replies: 1Last Post: 25th Sep 2008, 15:58 -
burning question...:-)
By Gunny in forum DVD RippingReplies: 12Last Post: 23rd Sep 2007, 18:54 -
After Burning a DVD question
By boomers03gmc in forum DVD & Blu-ray RecordersReplies: 3Last Post: 19th Jul 2007, 03:25
