I just bought a second HD for my computer. I am going to connect it in the following way:
1st IDE - OS HD (Master) + DVD ROM (Slave)
2nd IDE - DVD Burner (Master) + 2nd HD (Slave)
I think it is better to connect DVD Burner as Master, is that right?
kfc888
Or,
connect your hard drives on the same IDE channel (use the primary), then connect the recorders on the second. You will very seldom use the two recorders at the same time.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
I would also do the hard drives on one and the roms on the other. You'll often go from cd->hdd, but not as often hdd->hdd which is pretty much the only thing you'd gain by putting the two drives on different channels. Plus hard drives are quick enough that even on the same channel you won't see many problems. You'd also not really need to separate the roms simply because you won't (or shouldn't, anyway) go from cd->cd
hard drives
By Willy5157 in forum ComputerReplies: 7Last Post: 23rd Oct 2009, 04:16 -
Hard Drives
By hardy in forum ComputerReplies: 16Last Post: 27th Jun 2009, 18:00 -
The naming of Hard drives & Burners on WINDOWS VISTA
By orfajackson in forum ComputerReplies: 2Last Post: 3rd Jun 2009, 14:00 -
Hard Drives
By jason in forum Newbie / General discussionsReplies: 7Last Post: 14th Apr 2008, 11:50 -
Roms & Emulators on a USB External Hard Drive...will it work?
By Xenogear900 in forum ComputerReplies: 3Last Post: 28th Nov 2007, 17:31
