Results 1 to 9 of 9
  1. hello,
    i have captured a mpeg2-file (ca. 10GB) from my tv-card with "InterVideo Win DVD Recorder".
    now i would like to make a DVD-Video (or on 2-3 DiscsVD+R) from this file, can i make this with, for example, Nero or another burning software or must i reconvert or can i make only a "SVCD"...?
    Another question:
    is it possible to say to nero "make an new SVCD" (from this mpeg2-file) and let him burn on a DVD+R?
    Excuse my bad school english.
    thanks a lot fpor your help.
    best wishes
    stefan
  2. Depends on where you want to play it. Some players will play mpg on DVD+R but most don't. Check de DVD Players link (brown) on the left.
    What you need to do with your mpg to make it playable on a DVD depends on what you got exactly.
    If you already got a VCD or SVCD format use this tool (SVCD2DVD) to author your dvd.
    If it is DVD format use another tool to author the DVD like IfoEdit or any other dvd author tool you can find in the Tools link (brown) on the left
    If it isn't a VCD, SVCD or DVD format you need to convert your mpeg to any of these format. I suggest SVCD. There are 2 tools you can use for that tmpgenc or CCE. You'll info about this tools in the Tools link (brown) on the left. And guides about it in the Guides link (green) on the left.
    Just look around and try some guides, remember it isn't an easy process so be patient and use a DVD+RW till you are happy with your DVD.
    Greatings,
    Yf
  3. hello,
    thanks for your answer.
    by the program "windvd recorder" i have this settings taken, to record on HD:
    [DVD]
    Format: MPEG-2 DVD
    Audio:
    Format: MPEG-1 Layer II
    Abtastrate: 48.0 kHz 16-Bit Stereo
    Bitrate: 224 kBits/s
    Video:
    Größe: 720x576
    Bildrate: 25.00 Bilder/s
    Bitrate: 7200 kBits/s
    Gesamt:
    Bitrate: 7715 kBits/s
    Größe der Dateiteile: 4194303 MB.
    is it possibel to burn this mpeg2 file directly to a dvd+r without anything to concert or not?
    thanks for your help
    best wishes
    stefan
  4. Originally Posted by Maverick1304
    hello,
    [DVD]
    Format: MPEG-2 DVD
    Audio:
    Video:
    Größe: 720x576
    Gesamt:
    best wishes
    stefan
    7200 kBits/s! It's very high! My suggestion is that you author the file in svcd2dvd and then use dvdshrink to make it fit a dvdr.
    "Another question:
    is it possible to say to nero "make an new SVCD" (from this mpeg2-file) and let him burn on a DVD+R? "
    Yes, but cut in two or three parts first with tmpgenc(about 40 minutes for each part) and then "burn" with image recorder. After you extract the movie from the image. And, again, I suggest you use scvd2dvd to author the dvd.
  5. how do i take a .mpg file and burn it to dvd using svcd2dvd? i've only used it to burn .bin files
  6. You can use an author program (any program you find here and you like) to make a dvd out of your .mpg. It is in DVD format. Most of the tools also list the place where you can buy/download it and a list of guides how to use it.
    It is a very big file but it should fit on a DVD if it won't fit just use DVDShrink to make it a bit smaller.
    Greatings,
    Yf
  7. hello,
    can i use the program "Pinnacle Studio 8" to make a DVD from my mpeg-file?
    this program doesn't convert anything is this right? make only "VOB-files and so on..." what needs to make DVD-STandard from my mpeg-file is this right?
    with nero 6... it isn't possible to say make DVD from my mpeg-file?
    excuse my stupid questions (because iam a newbie) and my bad school-english.
    thanks
    stefan
  8. I don't know if you can use Pinnacle Studio 8. I never used it. About converting i don't know either some programs do and some programs don't
    What i do is the following:
    1. Make a dvd mpg file with tmpgenc (you don't have to do this cause your file is already an dvd mpg file)
    2. Then i use DVD-lab to author my dvd. This isn't an easy program to use but it is the most flexible when it come to menu's.
    3. Then i use DVD-Lab to compile me a dvd. Which consisist of a video_ts folder with files in it.
    4. Then i open Nero en burn the dvd by selecting make a Video-dvd and drag the video_ts folde DVD-lab made to the root of the dvd.
    Greatings,
    Yf
  9. hello,
    thanks a lot for your help.
    greetings
    stefan
