Can someone tell me what the trick is when using hte clear cd cabels to put them on so there are no god damn air bubles.. Thanks
I don't know, I guess you take your time I have never had any problems and I don't even use an applicator. If you do get bubbles you can try using a pin to get the air out. When you apply the label always push from the centre outwards this also helps.
Good luck.
Why does this video look so clear?
By brassplyer in forum Video Streaming DownloadingReplies: 4Last Post: 16th Jun 2009, 21:42 -
UV vs Clear Glass Filters
By thurnau in forum Newbie / General discussionsReplies: 2Last Post: 18th Apr 2009, 12:17 -
Is Clear QAM common?
By Mormegil in forum DVB / IPTVReplies: 11Last Post: 26th Oct 2007, 14:13 -
Making Corrections on Ink Jet Printed Lables
By jmpoer in forum MediaReplies: 5Last Post: 7th Sep 2007, 14:06 -
16bit Audio not Clear :(
By ozab in forum Capturing and VCRReplies: 0Last Post: 31st Jul 2007, 10:51
