Can I rip + shrink a dvd with dvdshrink all at the same time without using dvd encrypter first to decrypt it? cause it would save alot of time if i was able to rip and shrink at the same time instead of decrypting and waste much space on my HD and than shrink and than burn...
so anyway that's what i'm asking you guys:
Can I rip + shrink a dvd with dvdshrink when it's encrypted?
Yes you can rip and encode the movie with dvd shrink, all you then need to do is encode.
DVDDecryptorisn't required for any version newere than 2.3 . Curren version is 3.1.3
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I think hardcoreruss meant to say is, "then all you need to do is burn."Originally Posted by hardcoreruss
ok.. i figured that out.. heheI think hardcoreruss meant to say is, "then all you need to do is burn.
Yep, that is what I meant, thanksOriginally Posted by FT Shark
Russ
question about dvd shrink
By marlo in forum Authoring (DVD)Replies: 5Last Post: 29th Aug 2010, 04:22 -
Hello I'm New & I Have A Question About DVD Shrink 3.2
By taffy1967 in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2010, 04:28 -
question about DVD Shrink
By Bamahusker in forum DVD RippingReplies: 7Last Post: 1st Mar 2010, 20:48 -
DVD Shrink and Nero Recode question.
By siratfus in forum DVD RippingReplies: 8Last Post: 13th Jan 2010, 21:49 -
question regarding analyze in DVD Shrink
By Bamahusker in forum Newbie / General discussionsReplies: 2Last Post: 8th Jul 2007, 08:31
