I have a DVD with two audio tracks on it. When I made a backup of this DVD, I used smartripper to rip out all of the files so I would have the entire disc. Then I used DVD Shrink and set it Re-Authoring mode and took the Main Movie and one of the extra movies and made a DVD.
Now my question is, I have 19 chapters on the DVD. Chapters 1-18 are the main movie and chapter 19 is the extra movie. I have discovered that the extra movie has it's own audio track. When my DVD player reaches chapter 19, I hear no sound. I have to hit the "audio button" on my remote to hear the sound of the extra movie.
Is there anyway to set an option so that when chapter 19 is played, it will automatically switch audio tracks without me having to push the audio button on my remote?
My other question is:
I have taken a DVD movie with 2 differnt movies on it. One was the original version the other a special edition director's version.
I used smartripper to rip the video and AC3 stream of my choice out.
I then used IFO-Edit. I told it to do a DVD author. I took my steams and put them into the proper fields. (I'm not sitting in front of my computer right now to know the names of the fields, but you should get the general idea) Once this is done you can start the author process and IFO-edit will build you a complete VOB set off of your video & audio stream.
Now my question is "Why do I not have any chapter points left in my movie after doing this"? When I play the movie in PowerDVD, I have one large movie file with no chapter markings of any kind.
Does IFO-Edit's author feature not support chapters? If not, then what program will allow me to keep them when I rebuild the movie?
Thanks for any advice you can provide.
PM
DVDShrink 3.1 has the option to re-allocate the Audio streams and will solve your problem.When my DVD player reaches chapter 19, I hear no sound
You can also use IfoEdit command "Set Audio Stream nr" for that individual IFO
Because you didn't extract them from the IFO.Why do I not have any chapter points left
Open the original IFO, goto
VTS_PGCITI / VTS_PGC_1
Menu / Tools
Save Celltimes to file
Use that when Authoring.
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 02:56 -
Quick DVD LAB Pro question
By sterankin in forum Authoring (DVD)Replies: 5Last Post: 12th Aug 2010, 06:13 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 07:03 -
Hi havent done much dvd burning in awhile and had quick question
By pitten247 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2008, 21:10 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 09:40
