I'm sort of at a loss. I can't figure out what I'm doing wrong if any. I have both a g4 powerbook running at 1 ghz with 1.25gb of memory. But, I can't seem to load any movies burn with my pc. On the PC I used dvd+R and -R from Fuji and also the apple dvd-r disc. tried using nero and BHA Gold recorder. No luck. doesn't read and never mounts. Here's the kicker, all the disc that was burned will play fine on a stand-alone player and on the PC computer.
Any tricks to make my mac see the pc disc
My guess is the problem lies with the Powerbook's DVD drive. I'd say you might look into a replacement drive for it, or keep trying different media until you find one that works. Stick to -R media. Do data DVD-R discs burnt on the PC mount on the Powerbook?
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
any dvd disc burned using a mac is ok. once i use a pc to burn no good.
mac's typically read -r disks (especially the powerbooks)
in rare cases powebooks drives need to be updated using firmware updates to read -rw disks
This was typically with the older edition titaniums
i thought the new ones addressed this issue
id contact apple on this especially since yours is new. apple care will replace the drive if you have no problems
phone support is free for 90 days so just give them a call
1800-myapple
Problem w burn for Mac
By allakantralla in forum Newbie / General discussionsReplies: 1Last Post: 25th Dec 2011, 20:12 -
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 06:18 -
Best way to convert/burn/play .mkv H.264 Blu-ray/HD DVD files on a Mac
By iMacMan in forum MacReplies: 7Last Post: 21st Mar 2009, 17:50 -
How to Burn an ISO on the Mac
By Jeff_NJ in forum MacReplies: 6Last Post: 19th Nov 2008, 10:11 -
Capture PC burn for mac
By TripScott in forum Video ConversionReplies: 2Last Post: 5th Nov 2007, 15:34
