Is there a way to tell if a source video file (Divx inparticular) is encoded interlaced or not without first playing on a tv set.
i have a clip that is 25 fps and am asuming it is PAL at that frame rate, but wondering if it was interlaced .
Another quick question I have is whether the field order differs from NTSC to Pal. I assume that A field first is the norm, or does it matter. Should my ouput field order be the same as the source
I want to make an NTSC compatable DVD
If its divx, it won't be interlaced.
Can an interlaced file appear not to be interlaced on the monitor?
By rcavanah in forum Authoring (DVD)Replies: 5Last Post: 10th Sep 2011, 23:09 -
Interlaced.... or not?
By pgoelz in forum Capturing and VCRReplies: 29Last Post: 15th May 2011, 23:20 -
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 10:16 -
Convert interlaced HD to interlaced SD with AVISynth
By jorbje in forum Video ConversionReplies: 19Last Post: 22nd Mar 2008, 19:48 -
interlaced pc/TV
By pantsdavies in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2007, 21:58
