Hi,
I am new here can anyone please help.
I recently bought an NEC 1300a dvd driver and have fitted it as the primary driver. It burns CD-R's fine, and will read a DVD, but will not read any blank DVD that I put in. When I click on 'properties' it says 'free space 0 bytes'. I have tried Princo DVD-R (1-4x). I have tried TDK, and a super high-grade DVD disk. Before this I had a CD-RW installed as the primary driver and ahead INCD used.
The drive name is:
_NEC DVD_RW ND-1300A V1.09
Any help will be appreciated,
THANKS.
InCD and other packet-writing software in general are trouble-maker for ND-1300A. I had all kind of errors burning DVD before. Once I removed InCD, all problems were gone and my system become very stable since then.
If you still have INCD running it may help to uninstall. I have known this to cause problems with various DVD-RW drives!
Have you actually tried burning a DVD? Maybe windows is just incorrecly displaying the free space information!
Nick -
Hi Thanks for the advice,
have uninstalled but still have the problem, do i need to take anything out of the windows registry? As it still has something in there for INCD.
Thanks -
If you are running WinXP, try to disable the "IMAPI CD-Burning COM Service". It is under control panel | Administrative Tools | Services.
NEC NDH80 Gone B&W
By bawpcwpn in forum DVB / IPTVReplies: 1Last Post: 11th Jun 2008, 14:23 -
NEC AD-5170A Questions
By urb1972 in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Nov 2007, 20:39 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 21:07 -
NEC DVD Drives
By RapidRio in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2007, 13:13 -
NEC NDH81
By babagoi in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 19:05
