Im desperatlytrying to burn a DVD to play it on my Playstation2.
Can someone tell me what NERO settings to make, so that it funktions on a PS2 Player.
My Burning software is NERO Burning rom 6.0.0.9 and the media i used so far was DVD-R.
Ive created the Video files with DVDShrink. The Files VIDEO_TS are created properly but somehow i seem to have the wrong settings to burn in my NERO Burning rom 6.0.0.9
PS2 has a problem to reade the DVD even when i burn it with Nero Express.
There are no problems.........Just sollutions![]()
I have always used nero express and my backups play on ps2 no probs, but i dont burn too fast. What media you using and the burn speed? Because these might effect the reliability of the disc in playstation 2.
Try burning a little slower 1x or 2x and use an established brand of -R see if that helps any."Pull your tongue out of my ar$e hole Gary...dogs do that. Your not a dog are you Gary?"
"Err no...."
"But you do have all the characteristics of a dog Gary...all except loyalty." -
Hi...
I use nero 6.3 with DVD+R (Sony and Pengo) and works fine.....(The Sony is 4X speed burning)...
Made it with DVD Shrink....3.1 or 3.02
No special configuration on Nero, just DVD Video and thats it!
Good look.. -
PS2 is very picky about media. different models prefer different media. some like +r some like -r some will handle both and some hate anything. the newest ones are more prone to play anything.
Burn from to DVD but what format to play on tv?
By Claxlast in forum Authoring (DVD)Replies: 5Last Post: 18th Mar 2011, 17:57 -
Which DVD should I use to burn avi files to play on standalone?
By Stealth3si in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2009, 11:22 -
Converting WMV to burn on DVD to play on DivX
By ez2cy in forum Video ConversionReplies: 30Last Post: 20th Dec 2008, 04:54 -
Why can I not burn DVDs that play in my standalone DVD player?
By bmoreravyns in forum Authoring (DVD)Replies: 12Last Post: 18th Sep 2008, 15:05 -
PAL DVD will burn but not play
By vhsreject in forum Authoring (DVD)Replies: 6Last Post: 5th Sep 2008, 03:07
