Ive been burning projects successfully when i burn onto a dvd+rw disc, but when i try to burn onto a dvd+r disc, my dvd player cant read it.
I have set my player on all region and it plays all copys svcd's vcds etc..but will not play my project on a dvd+r disc!
why is this?
can anyone help? as its most frustrating![]()
Does your player support +r discs ?, does the disc play on the pc ?
yes it plays on my pc ok. and unsure weather my player supports +r discs!
Wat is the difference between +r & +rw? i know +rw is rewritable but i dont understand why my standalone wont play in +r (single use) -
I am not sure if +r would be supported purely because +rw is. Have you any other type of media to use to check, so still +r but a different make of disc.
not just as yet . on the job tho.
cheers mate will let you no how i get on! -
[quote="mushkin"]on the job tho. quote]
We don't want to know about your private life here !!
[quote="garryheather"]
Originally Posted by mushkin
Problems copying Blu-Ray disc...
By waldothewonderboy in forum Newbie / General discussionsReplies: 4Last Post: 1st Jan 2012, 20:41 -
Re: dvd disc back up problems
By macca62 in forum Newbie / General discussionsReplies: 3Last Post: 14th Mar 2009, 11:24 -
problems with 10,000 BC DVD disc
By Gabriella555 in forum DVD RippingReplies: 2Last Post: 3rd Jul 2008, 07:35 -
?? Disc problems
By dazzaboy2 in forum Newbie / General discussionsReplies: 2Last Post: 11th Oct 2007, 12:51 -
DVR pioneeer 510H disc reading problems
By cistec in forum DVD & Blu-ray RecordersReplies: 5Last Post: 26th Aug 2007, 00:13
