I use an eMac with superdrive and usually if backing up a dvd i would use DVDbackup > DVD2One > Toast
In this case i have recorded a film from tv using my philips dvd recorder which recorded it onto a DVD+RW. Problem is i started it recording like 5 mins before movie started and it has ad breaks in the middle.
what i want to do is re-author it to start the movie in the right place and cut out all the ad breaks one by one, then burn onto a DVD-R.
what programs can i use, for the mac, is there any guides on here i can use and how easy is it to do!!
hope someone can help.
cheers.
Ross.
first things first....
DOES THE +RW MOUNT IN YOUR IMAC DRIVE!?!?!
if not then you have a major issue to look at! -
dvd studio pro 2 will let you cut out stuff. you wouldn't have to re-encode either. just demux, then import, then cut out. just cuts thoughs, no transitions or anything.
or you could use dsp 1.5 and just set markers at the comercials and use stories to skip over that content.pants on, pants off, pants the floor. -
hi pants,
thanks for the response! the good news is that i have been able to get my hands on a copy of DVD studio pro 2. The bad news is im a newb, i have never used the program and dont know a great deal about authoring at all. I dont know what demux means? do i need a seperate program to do this or can i do it from within dvdstudio pro 2? then once it has been demuxed what format will it be in and how do i go about cutting it. Sorry if this is a big ask but i need some help guys.
cheers.
Ross -
in that case you should do lots of reading!!!!!!!!!!!!!!!
its not a difficult process, but its not something that is learned in one sitting.
it would be no problem for you to make copies of it, but like you said the commercials are in there.
thus you have to "import" the contents to an authoring (dvd making) software so you can edit out the unnecessary info and save / export the final project to your harddrive for burning
dvdstudio pro is perhaps the best app, but its not the easiest to use the first time around.
so i would look at how much you want the commercials cut out and how much you will need to learn for this process to occur. If you plan on doing this a lot its well worth the few evenings palying around with the app and reading the 1000 page (hahah is it really that big) manual on the app.
if you have questions as you go there are masters of dvdstudio pro who reply here and i am sure they can help you out
I prefer not to use the app 1. because its expensive, and 2. ill just live with the commercials -
to demux, try ffmpegx,
http://homepage.mac.com/major4/videots_divx.html
or moremissing tools.
http://homepage.mac.com/rnc/.Public/MoreMissingTools.zip
either should work, this will give you .m2v/.mpv and .aiff/.mp2/.ac3/? not sure what audio format your stuff will be in.
take these into dsp2, drag into time line and can edit there. either grab the end of the track and drag it in to where you want to edit or select track in time line and then in the inspector under clip info you can trim or change duration. not the easiest thing to do, but it works.pants on, pants off, pants the floor.
890922 - How to cut a DAT file out of ads?
By hamidi2 in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2010, 10:41 -
Want to copy Blu-Ray film only no menus, previews, ads, etc.
By jcikal in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2010, 16:49 -
new recorded dvd can not be played or recorded on after the recording is do
By dlaleh1 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 24th Jan 2010, 23:06 -
Recorded video, i want to cut my self out of it.
By aiitexx in forum Software PlayingReplies: 2Last Post: 13th May 2009, 21:55 -
How do i author dvd menu with chapters + cut commericals...with a WMV??
By chocolate_brownie in forum Authoring (DVD)Replies: 0Last Post: 2nd Jun 2007, 20:00
