I found a cheapy nasty method to converting mpg1 to mpg2 files with dvd2svcd with cce instead of using tmpgenc which is really slow for doing that.The reason i encode up is to make pal mpg1 into ntsc mpg2 which is much easier doing it as ntsc film in mpg2.If anybody is interested just ask,if not no problem.
Did you want to know how to do this or just liked the cheapy nasty comment?
You consider cce cheap? Most people who have it were nasty
Panasonic DMR-ES45VS, keep those discs a burnin' -
Ok,what i do first is load a short (ntsc)avi clip into dvd2svcd and let it get into the encode stage and then shut down dvd2svcd after encoding has started.Then get the mpg1 file and load that into virtualdub and frameserve it and name it the same as the avi file you were just encoding.then start up dvd2svcd and do a crash recovery with the frameserved avi file in place of the real avi file you were encoding.You can add in comments to the script for AssumeFPS(23.976) if you got edit as part of video encoding checked in the frameserver tab in dvd2svcd for pal mpg1 and if the original avi you used to start dvd2svcd has a wrong frame rate then dvd2svcd will automatically put in the AssumeFPS(23.976)
and also run pulldown on the file.You will just have to change the mp2 in besweet from 25fps to 23.976 manually afterwards.Hope this is easy enough to follow.
VCD MPG1 file to CD Question
By Excelsior123 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 22nd May 2008, 19:14 -
Problem converting HD (.mkv) to DVD (.mpg2) with TMPGEnc
By KPKMP33 in forum Video ConversionReplies: 4Last Post: 9th Nov 2007, 09:36 -
avi to mpg1
By zoranb in forum MacReplies: 3Last Post: 12th Sep 2007, 14:46 -
Minimum MPG1 file size?
By Choppa in forum Authoring (VCD/SVCD)Replies: 17Last Post: 17th Jun 2007, 23:04 -
Strange problem converting Xvid AVI to MPG2
By joelore in forum Video ConversionReplies: 18Last Post: 1st Jun 2007, 23:40
