I'm new to the forum and i'm looking for a little bit of help with my burner. I used to never have trouble with my brothers burner that i borrowed for a few months - he had a DVD-r and now I have a TDK inkiDVD+/-R/RW. I used dvdshrink and burnatonce for software and it worked everytime. Now, i tried to use the same products and my burner stops after about 5 min. of burning and says it's done! So, I got DVD X-Copy Express Platinum. It basically does the same thing. I can rip the DVD with DVD X-Copy and then it asks to insert a blank DVD and continues to burn for 5 min and says its done and there's a disc error. I am burning with a generic media of DVD-R's (which served me well and fine in the past).
I hope someone can help me here! I'd appreciate any kind of input - am i using the wrong software? Did i do something wrong when I installed the drive? Also...if this helps...I recently formatted my computer before installed the new drive.
Thanks for any help you can provide!
john
Results 1 to 1 of 1
DVD Burner Freezes When I Try to Copy a DVD
By w6rlf in forum DVD RippingReplies: 5Last Post: 7th Dec 2009, 14:41 -
Can't burn DVD using TDK burner
By tee jay in forum MacReplies: 7Last Post: 16th Sep 2008, 15:01 -
Dvd Burner Wont Copy
By Catman209 in forum DVD & Blu-ray WritersReplies: 12Last Post: 16th Dec 2007, 00:35 -
Trouble burning DVD+R DL with Pioneer burner
By RoyGBiv-inRI in forum DVD RippingReplies: 11Last Post: 17th Oct 2007, 11:43 -
Different dye coloration after burn (TDK DVD)
By xSimonx in forum MediaReplies: 2Last Post: 24th Sep 2007, 21:29
