  1. is there a way to use TMPGE to encode uncompressed AVI files? every time i try i get the error "not Supported". i think i need a codec but i don't know what it is. any help????
  2. Odd, TMPGenc should just be able to read it. What's the frame rate of your avi?
  3. 29.97max, it ranges from 29.95 to 29.97. when i capture it starts at about 26.5 then moves up to that range within about 10 seconds. when it gets to that range it stays there but doesn't stay at 29.97. it fluctuates in that range.
