im using dvdshrink to encode my dvds, how do i know which audio tracks are comentary and which arent? and also whats considered a bad compresion ratio, what percentage is to low?
Results 1 to 9 of 9
usually director's commentary will be labeled "director's commentary" in the audio track list.
Another thing you can do is, uncheck all the audio tracks except for the one you want to keep and preview the movie. The new dvdshrink (verson 3.1.xx) plays audio as well as video.
I usually like to keep my compression at 75%+. If the compression falls below 75%, I'll reauthor just the main movie. -
well for example jackass the movie has 1 5.1 audio track and 3 2channel tracks, how do i know which is comentary because none say if its commentary or not?
try previewing them?
do the 3 - 2 channels say english, spanish, french, etc? some dvd's list a bunch of audio tracks are dubbed in different languages. -
so basically just throw on all the video stuff that i want and it will play in a row without the menus?
yep.
you have 4 choices.
1. shrink the entire movie with all the menus, take out all the audio, subtitles, etc that you don't need.
2. use a dvd authoring program which allows you to create your own menus.
3. reauthor adding just the main movie and any of the extra footage, which will play without menus.
4. read guides on how to use ifoedit, to keep all menus, etc. -
I may be old fashioned, but the tried and true way is to actually put the disc in and play it. You'll get a firsthand account of what each track is without any mistakes. Just throwing that out since it seems to not be an option for some reason
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 08:45 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
Compression questions
By ishal in forum EditingReplies: 5Last Post: 31st May 2009, 22:21 -
Questions about "Audio Compression" on digital cable box.
By Xylob the Destroyer in forum DVB / IPTVReplies: 1Last Post: 21st Feb 2009, 13:39 -
Fraps: Video Compression etc. Questions
By Tinfoil in forum Newbie / General discussionsReplies: 25Last Post: 16th Jan 2009, 15:47
