everyone im using nero 6 ultra edition and it only lets me write @2x
why cant i do 4x which my burner is?
Are you sure ?
Just because it says that on the top doesn't prove anything at the moment. It depends a lot on the true manufacturer and your recorder and its firmware.
What is the media code of the disc and the writer you're using ? -
I have a Sony burner and this will only burn 4x on high quality media if I use princos or anything like that nero will show the option of 4x but still only burn at 2x.
Try changing your media.
firmware burning problem
By weedhopper in forum DVD & Blu-ray PlayersReplies: 6Last Post: 1st Aug 2010, 11:34 -
BDMV burning problem
By rickoshay in forum Authoring (Blu-ray)Replies: 2Last Post: 12th Jun 2010, 04:48 -
Problem with burning.
By googoodolls in forum DVD & Blu-ray WritersReplies: 7Last Post: 12th Dec 2009, 06:20 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 12:39
