Sounds to me like your MPEG-2 files are not quite technically compatable. Check out the bottom of this page for some general info:
http://www.vcdhelp.com/dvd.htm
And then check elsewhere on this site for more technical details.
Also, I know it's just a hobby, but you will really get MUCH better results if you use TMPGEnc to encode your files. The quality difference is really striking.
Results 181 to 210 of 226
Does anybody knows if this program has the same good results creating DVDs? Not just SVCDs?
Answer in English, Spanish or Portuguese! -
Regarding the Ulead download server: I had some problems with it too, downloading manuals. Finally, for kicks, I tried a command line FTP (the one that comes with windows). It worked repeatedly, no problem. I have no idea why, maybe it was even just good timing...
I just got Movie Factory, and I'm looking forward to playing with it. I think I'm going to keep using vdub and tmpeg for making the mpeg, but I got frustrated with CD-Maker deluxe's lack of functionality
for VCD and SVCDs, so hopefully Ulead doesn't let me down... tips anyone? I'll post results later.
Why are the easy things always so difficult?
Trying to create a DVD using ULEAD DVD moviefactory. Imported digital video via Uleads MediaStudio Pro. My problem concerns menus. 2 different problems.
In 1 case I was able to select the desired chapter points. Edited the thumbnails, chose a menu etc. Tested the preview in the software everything seemed perfect. Burnt the DVD (DVD+R on an HP DVD200i) no difficulties in the process. When playing the DVD the timing of the chapter points is way off. It is progressively worse with each point. When you click on the menu item the video begins from several seconds to 15 or 20 seconds prior to where I had selected.
In a different attempt I am unable to locate scene frames for large sections of the video. Initially I could and as I continued to edit the project it went weird on me.
Any input would be greatly appreciated.
Dave -
Hey there. The Sync problem has been noted in the past (you might try scanning some of the posts for details).
First of all, what platform are you on (WinXP, Mac?)? Second, have you run the patch from their site? Third, are you using a single, long clip?
From what I recall, the problem is worse if you use a single long clip. If possible, restrcture your clip into a few smaller clips. That should prevent the problem from "creeping" with time (small errors add up to create larger errors the longer you go).
I usually only use 30-45 minute clips with VCD and SVCD (don't have a DVD burner, yet), and find that works well. -
Ulead DVD factory and workshop are serviceable little programs. I get the best results encoding with CCE or TMPGenc ahead of time, and feeding finished files to Ulead for authoring.
I don't even mind the cheesy menus most of the time. People who visit me and see my homemade DVDs think the menus look spiffy.
Much less work than generating custom ones...
-MPB/AZ -
To answer your questions:
I am running Windows 2000
It is one long clip (roughly 32 minutes)
I have run the update from their site
If I break the clip up into smaller pieces will it allow the video to run straight though start to finish or will it return to the menu when each clip completes?
As for the sync problem I had not seen info regarding it but I will search again.
Thanks -
Will it return to the menu when each clip is finished playing? Hmmmm. It might, but there is a way to prevent that. I'll check it out and let you know tonight.
"If I break the clip up into smaller pieces will it allow the video to run straight though start to finish or will it return to the menu when each clip completes?"
Davem -
I've use Movie Factory for both short clips (music videos) and long clips (1/3 of a movie) in the XVCD format. (Sorry, no DVD experience) With the music videos the only chapters were at the beginning of each video (obviously), but with long single clips I inserted multiple chapters. When playing the disk on my Apex 500W, if you select a certain chapter it plays only that chapter and then returns to the menu. This applies to disks with multiple short clips or one long clip. So, in this case it doesn't act like a DVD movie. If there is a way to get it play from a selected chapter to the end of the disk, I haven't figured it out. If you select "Play" while the menu is displayed, the disk will play from beginning to end, including the intro video, if it has one. One thing I noticed, though. If you break up a long clip like a movie into smaller clips and then play the disk from beginning to end, there is a brief but noticeable pause from one clip to another. Not good for continuous things like movies, but just fine for music videos and family video events. Granted, my experience is limited to the Apex player in this regard. I've never tested a movie broken up into small clips, each with it's own chapter, on any other player. Also, I've only burned a few movies having one long continuous clip and multiple chapters. I haven't noticed a timing problem where the chapters begin playing, but I probably haven't paid close attention to that. I like Movie Factory a lot and feel it's worth every penny they charge for it. I use Media Studio to edit my DV AVI's, TMPGEnc to convert to mpeg, and Movie Factory to burn the disks. I do have my gripes, like the previously mentioned lack of flexibility of fonts. Also, I can't get MF to accept VBR mpegs, only CBR mpegs seem to work. Like others in this thread, I would like to have a warning pop-up box informing me of a non-compliant mpeg, explaining what is non-compliant about it, but giving me the option to go ahead with the burn.
I hope my ramblings help you out somehow.
[edited. puctuation got weird]
hey guyz I have converted like 3 or 4 times some mpg files into vcd format with tmpgenc and yet when i open ulead dvd movie factory i get this message after choosing to author menu"Load MPEG vio Driver Error C:\Progam Files\ULEAD SYSTEMS\ULEAD DVD MOVIEFACTORY Trial\Dvd Movie Factory\ulead.dat\DvdPlugin.ini"i hit ok then when i choose Vcd i hit add mpeg file when i choose the vcd file it says unable to open file.File Format mismatch.What am I suppose to do?Thanks in advance
I would like to post this question to travisawhite. I was wondering why does the Movie Factory would NOT let me burn a Mpeg1 VCD with variable bit rate. I had to go back and use Nero. I would like to use the Movie Factory but no way it would let me. Is there or will there be a modification for this?
Steve -
I was just wondering why when the selection screen comes on it is toward the top of the tv screen, and the top is cut off. Is there anything I can do to fix it. I am using the trial version if that makes a difference.
Hello all,
I am a blind user who is looking at using Moviefactory to author and burn dvds. I am unable to use my mouse and was wondering if anyone new if this program would cause any problems for me. I do not want to create any menus but just have the movie play directly. Also, are you able to have.ac3 files with this program. Someone told me that you had to convert to .mp2 files and could not have Dolby Digital 5.1 audio in the final project. Any help would be great. Thanksblindy -
blindy007: you might have a problem with the first menu. It doesn't allow you to use the keyboard to navigate between the first menus. These being "Capture Video" "Author menus" "Burn disc images" and "Make cd labels and covers".
You can however just run the .exe files in the ulead folder.
As for .ac3 I am not sure. Someone else is bound to know though.
Koops -
Hey thanks for the great tip but I looked in the folder and did not see anything that would work. I saw a file named first screen and it brought up the first screen. I saw a file named dvdmoviefactory but when I hit enter on it it was a Acrobat file. Am I looking in the wrong place? Thanks
blindy -
Hey,
Nevermind I got it! Thanks a bunch I think I can actually keep my burner now. If anyone knows about the .ac3 I would be very happy. I was told by someone who was not sure that only Ulead Workshop could do .ac3 files. Also, one other question dvd moviefactory needs a actual .mp2 file correct? I mean you can not load a .m2v and .ac3 file like in Spruceup or other programs. So I would use Tmpgenc to create my .mp2 file and burn with moviefactory. Thanks a bunchblindy -
blindy007: I have only used it for 3 dvd-r's so far and I just created the mpeg2 file with muxed audio in tmpgenc.
I then just opened this file in DVD MovieFactory (author menus) and let it do some muxing (doesn't that that long) and the iso creation.
Koops -
I am a bit slow when it comes to making and figureing out this stuff. Let me tell you what I have done and if you could let me know what I am doing wrong and what I should change.
1. Ripping the dvd with Smartripper and demuxing the audio and video file separate. I end up with one .m2v file and 1 ..ac3 file.
2. Here Ineed to use rempg2 if my .m2v file is larger than 4 gigs.
3. Following the Newbie guide I should use Spruceup now to author and burn the dvr but I can not use Spruceup and that is why I wanted to use Ulead.
What do I do now with my two files or am I doing something wrong. Thanks a bunchblindy -
hmm, I am not to familiar with spruce up. But if I had the files you do I would try the following.
use rempeg2 to re-encode the video file to what ever you want. Then mux the audio and video together into a mpeg2 system file.
This then should be able to be imported into Ulead and then a DVD created into either video_ts or iso format.
I'm not totally sure about the .ac3 audio however. I need to try it out myself but I loose access to the dvd-r machine after tomorrow
Koops -
Well, I already had a .mp2 file that I tried loading into Ulead but it said it had aan audio stream that was not supported. So I guess that answers the question about .ac3. So I gues I will have to rencode the .ac3 files into a .mp2 file then combine the video and audio and then burn. Have you ever tried Ulead Workshop? That is suppose to handle .ac3 or DD5.1 files. I downloaded a trial version but do not know how to use it. Wondering if there is a .exe file like in movie factory and if the set up is the same. Well, thanks again for all your help.
blindy -
I've enocoded some SVCD files from TMPGEnc (compliant to the SVCD NTSC spec). But when I try to open them in Ulead MovieFactory (Authoring) they don't seem to want to load. Nothing happens and the file doesn't show in the field?????
Quick question. I am trying to create dvd compliant mpg files with dvd to svcd. Then author and burn with Moviefactory. But, when I go to load the mpg file I get an message saying not a compliant mpg2 file. Is it possible to back up a dvd with Dvd to Svcd and burn with Moviefacotry? Here is my settings file for DVD to SVCD. Thanks a bunch.
[Executables]
PVA Executable=
vStrip Executable=C:\Program Files\DVD2SVCD\vStrip\vStrip.exe
DVD2AVI Executable=C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.exe
BeSweet Executable=C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe
MadPlay Executable=C:\Program Files\DVD2SVCD\MADPlay\madplay.exe
MPEG51 Executable=C:\Program Files\DVD2SVCD\MPEG5.1\pub_enc.exe
CCE Executable=c:\cce\cctsp.exe
VFAPI Executable=C:\Program Files\DVD2SVCD\VFAPI\Reader\VFAPIConv-EN.exe
TMPGEnc Executable=
Pulldown Executable=C:\Program Files\DVD2SVCD\pulldown\pulldown.exe
SubMux Executable=C:\Program Files\DVD2SVCD\WinSubMux\WinSubMux.exe
bbMPEG Executable=C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe
I-Author Executable=
VCDImager Executable=C:\Program Files\DVD2SVCD\VCDImager\VCDImager.exe
VCDXBuild Executable=C:\Program Files\DVD2SVCD\VCDImager\VCDXBuild.exe
CDMage Executable=
RunPerCDImage Executable=
RunFinal Executable=
MPG2Dec DLL=C:\Program Files\DVD2SVCD\MPEG2Dec\mpeg2dec.dll
InverseTelecine DLL=C:\Program Files\DVD2SVCD\InverseTelecine\Donald Graft\decomb.dll
Subtitle DLL=C:\Program Files\DVD2SVCD\Avisynth Subtitler.dll
BMP Loader DLL=C:\Program Files\DVD2SVCD\Avisynth BMP Loader.dll
SimpleResize DLL=C:\Program Files\DVD2SVCD\SimpleResize\SimpleResize.dll
Title Picture=C:\Program Files\DVD2SVCD\DefaultTitlepicture.bmp
Change CD Picture=C:\Program Files\DVD2SVCD\DefaultChangeCD.bmp
[Folders]
PVA Folder=D:\
DVD2AVI Folder=D:\
vStrip Folder=D:\
Audio Folder=D:\
CCE Folder=D:\
TMPGEnc Folder=D:\
Pulldown Folder=D:\
bbMPEG Folder=D:\
I-Author Folder=D:\
Subpictures Folder=D:\Subs
[Settings]
XPos=0
YPos=0
FirstRun=0
Resize AVS Position=1
TemporalSmoother AVS Position=2
Sharpen AVS Position=3
UsePVA2SVCD=0
UseDVD2SVCD=1
UseAVI2SVCD=0
UseMPEG1=0
UseMPEG2=1
Convert to Canopus codec=0
Convert to Divx4=0
Use Frameselection=0
New Default Folder=0
DVD2SVCD Level=1
UseDVDRip=1
UsevStrip=1
UseInternalRip=0
Eject DVD=0
iDCT=0
DVD2AVI Pause=0
Luminance Gain=0
Luminance Offset=0
Audio1Downsampling=0
Audio2Downsampling=1
Audio1BitRate=13
Audio2BitRate=7
tooLame Mode=0
Autodetect Azid Gain=1
Folder Structure Source=
Folder Structure Video=
Folder Structure Audio=
Folder Structure Muxed=
Folder Structure Subs=Subs
Intra=8,16,19,22,26,27,29,34,16,16,22,24,27,29,34, 37,19,22,26,27,29,34,34,38,22,22,26,27,29,34,37,40 ,22,26,27,29,32,35,40,48,26,27,29,32,35,40,48,58,2 6,27,29,34,38,46,56,69,27,29,35,38,46,56,69,83
NonIntra=16,17,18,19,20,21,22,23,17,18,19,20,21,22 ,23,24,18,19,20,21,22,23,24,25,19,20,21,22,23,24,2 6,27,20,21,22,23,25,26,27,28,21,22,23,24,26,27,28, 30,22,23,24,26,27,28,30,31,23,24,25,27,28,30,31,33
Matrice Preset=
Use deafult Matrice=1
LFEDownmixLR6Ch=-3
LFEDownmixLFE6Ch=0
CenterDownmix6Ch=0
SurroundDownmix6Ch=0
DynamicCompression6Ch=1
StereoDownmixType6Ch=0
RearChannelFiltering6Ch=0
DialogNorm6Ch=0
LFEDownmixLR2Ch=-3
LFEDownmixLFE2Ch=0
CenterDownmix2Ch=-1
SurroundDownmix2Ch=-1
DynamicCompression2Ch=1
StereoDownmixType2Ch=0
RearChannelFiltering2Ch=0
DialogNorm2Ch=0
No Audio Conversion=0
TemporalSmoother Strength=2
TemporalSmoother Radius=1
Use TemporalSmoother=0
Use Sharpen=0
Sharpen Value=0
ResizeMethod=2
Avisynth Bicubic b Value=0
Avisynth Bicubic c Value=0.75
Flip Vertival=0
Add ResampleAudio=1
Resize To=1
Use CCE=1
Use TMPGEnc=0
CCE Safe Mode=0
NoOfpasses=3
CCE Image Quality=17
CCE Anti noise value=2
CCE Anti noise=0
CBR=0
One Pass VBR=0
Multi Pass VBR=1
CCE Field Order=2
Progressive=1
Auto Intra DC=0
DVD Compliant=1
Restrict auto I frame insertion=0
Close all GOPs=0
Intra DC=2
M GOP=3
MN GOP=5
SEQ Header=1
Constrained Parameter Set=1
TMPGEnc Rate Control Mode=2
TMPGEnc Motion search precision=4
TMPGEnc Field Order=2
Frames pr spread=50
Spread=40
OffsetFixed CQ Value=80
Use fixed CQ Value=0
DC component precision=2
Output YUV data as Basic YCbCr not CCIR601=0
Use floating point DCT=1
No motion search for still picture part by half pixel=1
Soften block noise=0
Soften Intra=35
Soften NonIntra=35
TMPGEnc GOP I Pictures=1
TMPGEnc GOP P Pictures=4
TMPGEnc GOP B Pictures=3
TMPGEnc SEQ Headers=1
TMPGEnc Max frames in GOP=0
TMPGEnc Close GOPs=0
TMPGEnc Detect Scene Change=1
Enabled Padding=0
Dont Delete Files=1
Create VAF=1
QFactor=5
Linear quantizer scale=1
Zigzag scanning order=1
Use2Streams=0
Pri1Audio1=28
Pri1Audio2=-1
Pri2Audio1=-1
Pri2Audio2=-1
Sub1=-1
Sub2=-1
Sub3=-1
Sub4=-1
Sub5=-1
Sub6=-1
Sub7=-1
Sub8=-1
Azid Gain Offset=6
SubOutputPalette0=clBlack
SubBlendPalette0=0
SubOutputPalette1=clWhite
SubBlendPalette1=15
SubOutputPalette2=$001E1E1E
SubBlendPalette2=15
SubOutputPalette3=clGray
SubBlendPalette3=15
Rip subtitles=0
Min. Delay. Between Subtitles=100
Resize Subtitles=100
SVCD subtitles=1
CVD subtitles=0
Permanent subtitles=0
PAL Y-Pos=-1
NTSC Y-Pos=-1
bbMPEG MPEG1=0
bbMPEG VCD=0
bbMPEG MPEG2=0
bbMPEG SVCD=0
bbMPEG DVD=1
bbMPEG VBR=1
bbMPEG Pad VCD=0
bbMPEG Write PEC=1
bbMPEG Add Scan Offsets=1
bbMPEG Align Sequence Headers=1
bbMPEG Use Private Stream 2=0
bbMPEG Computed Bitrate=1
bbMPEG TimeStamps=0
bbMPEG Pulldown=2
bbMPEG MuxRate=0
bbMPEG Pack Size=2324
bbMPEG Packets Pack=1
bbMPEG Video Buffer=230
bbMPEG Audio 1 Buffer=4
bbMPEG Audio 2 Buffer=4
bbMPEG videoDelay Adjustment=180
bbMPEG audioDelay Adjustment=180
bbMPEG audio1Delay Adjustment=180
Use MPEGAV=0
MinsHigh1=95
MinsHigh2=100
MinsHigh3=100
MinsHigh4=125
MinsHigh5=163
NumCd1=1
NumCd2=1
NumCd3=1
NumCd4=1
NumCd5=1
NumCd6=1
CDSize 1=2175
CDSize 2=2175
CDSize 3=2175
CDSize 4=2175
CDSize 5=2175
CDSize 6=2175
MaxBitrate=9800
MinBitrate=300
MaxAvg=6000
MinAvg=1600
Adjust Audio Bitrate=0
Use Min. Avg.=0
Force Film=0
Movie Offset=2
CDOverlap=2
UseCDOverlap=1
FixedChapters=1
DVDChapters=0
PBCType=0
Data Preparer=dvd2svcd
Use I-Author=0
Use VCDImager=0
No images=0
Use VCDXBuild=1
Length of Chapters=60
Use TitlePicture=1
Use ChangeCD Picture=1
Use ChangeCD Picture on All=0
Use EntrySVD=0
Save XML=1
Save Movie Info=1
ProcessPriority=1
SmartDeinterlace Mode=2
SmartDeinterlace Treshold=10
SmartDeinterlace Denoise=1
SmartDeinterlace Blend=0
SmartDeinterlace Fast=1
Edit Avisynth Script file=0
Use CDMage=0
RunPerCDImage=0
RunPerCDImage Params=
RunFinal=0
RunFinal Params=
Automatic Shutdown=0blindy -
Sorry for thesize of the llast post. Did not think it would take up that much space. Should have made it smaller. Sorry again!
blindy -
The info button says:Originally Posted by Dragonsf
File:
File format: MPEG-2 Field A
File size 468,556 KB
Duration: 1776.476 Seconds
Video:
Total Frames: 53,241
Attributes: 24 Bits, 480x480
Frame Rate: 29.970 Frames/Sec
Data rate: Variable bit rate
Audia:
Total samples: 78,342,613 Samples
Attributs: 44100 Hz, 16 Bit, Stereo
Layer: 2
Bit rate: 128 kbps -
Cooly-O
This was happening to me for the last couple of months. You select a SVCD file, the program kinda blinks, and then nothing. No error message, no thumbnail, nothing. I just ignored the problem and only burned VCD's for a while. Finally, a couple of days ago I decided to uninstall/reinstall the program. After I did that it worked fine. I think Ulead programs are very sensitive to other video related programs installed on your PC. (Especially the ones you install after installing the Ulead programs.) -
TuxO,Originally Posted by TuxOmatic
I think you're onto something. It used to work for me fine. I have installed other similar programs since. Since the SVCD isn't working I tried to bring in a VCD file. It came in but won't let me add multiple menues (just the one for the file). It's acting flakey. I'll try to reinstall tonight. I have high hopes. Thanks much. -
TuxO,Originally Posted by Cooly-O
You were right. When I was unistalling the program I opted for the "Repair" option and that fixed all the wackey things the program was doing. Thanks again (very much).
BTW, How do you change the template settings so (to set a high bitrate so it doesn't re-encode)?????
Ulead DVD Movie Factory 6 Plus
By orientaldragon in forum Newbie / General discussionsReplies: 8Last Post: 2nd Apr 2011, 09:48 -
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 13:22 -
Ulead DVD Movie Factory and Vista
By qpskfec in forum Authoring (DVD)Replies: 1Last Post: 4th Jan 2008, 15:08 -
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 08:14 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 19:20
