ohh it will have to encode it, thats one of the nice things about toast 6.0 you can drop a .avi in and have it convert it to dvd automatically (via encoding)
however it often results in a file thats is too large for a dvdr, thats why im saying try it and see if it is too large or not.
Make sure you have 1 full .avi of all yoru parts (use ffmpegx to put them together like I explained above) then drop that single .avi into toast
Click VIDEO
Click DVD-VIDEO
Set it to your File Type (NTSC or PAL)
Drag the .avi to the DRAG VIDEO FILES OR PICTUERS INTO THIS AREA
You will see a section with the VIDEO and a EDIT BUTTON
push EDIT
at the Top you see TEXT and VIDEO tabs
push VIDEO
A drop down menu for DVD CHAPTERS will allow you to put chapter marks in your dvd using the times noted
when dont hit DONE
then rather than clicking BURN go to FILE and SAVE AS. this will begin to process the file to a MY_DVD.IMG which is a dvd image ready to burn
as long as its under 4.4 gigs your set and you can then use toast to burn this image![]()
Results 31 to 41 of 41
no problem
let me know the results
I forgot to say you can have it make a menu also, when in the VIDEO tab of EDIT you can choose the menu button of the movie by advancing the movie along and then choosing that portion as the button
so in effect you dont have to have it be one large .avi if you want more than one button.
does that make since
likewise the TEXT button is where you affect what will show you next to the button text wise
hope this helps -
Ok have played with the programme and almost there!
Have managed to produce 2 workable bin/cue files that are both visually and sound fine! However the resulting MPEG has an approximate 28 second delay on the sound (quality perfect) this happens from both MEPG file created by FFMPEGX and also when I attempt to create using Toast through the bin/cue copy function.
I can't see the word for the trees! How do I realign the audio onto the visual?
Thanks.
Richard. -
sync is an issue when you dont have the proper frame rate for the audio
try to find the frame rate of your avi and then set ffmpegx to that frame rate -
to be honest the way I do it is split up the divx into a small (10meg) clip
and proces it using all the avaliable options
shoudl not take long at all
find the one where this 10meg clip is synced
use that for the whole project
Test them ALL! -
Hey galatica i've got another question how do you make mpg's into a dvd I tried the method you said with the avi's and that doesn't work any suggestions.
several ways work
is it mpeg1 or mpeg2
can you give me the specs on the files....
frame rate. etc -
if they are .mpeg files you can use mpeginfo an app to get info for the mpeg
but essentially you would follow the SVCD to DVD guide on my website just skipping down the parts where you already have a .mpeg file
hope this helps some
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 16:23 -
How do you make a simple html file showing list of files in a folder?
By yoda313 in forum ComputerReplies: 2Last Post: 6th Mar 2010, 20:12 -
Make Blu Ray folder structure w/o re-copying the m2ts file
By stew181 in forum Authoring (Blu-ray)Replies: 3Last Post: 9th Jan 2010, 10:14 -
It took 11 hours with TMPGEnc 3 to make a 2 hour video folder
By nhbfan12345 in forum Authoring (DVD)Replies: 3Last Post: 9th Dec 2008, 14:18 -
Avi->DVD no Video_TS folder
By gaikoku in forum ffmpegX general discussionReplies: 7Last Post: 13th Sep 2008, 12:11
