    May 2003
    Canada
    I just bought a LDW 451s and I want to make sure im at the lattest firmware b4 i burn... I see on the main liteon website that there is a firmware update for my burner but since its new it might already be on it?
    so I just need to know how I check what firmware im currently running thanks.
  2. Go to Device Manager and select your drive and hit Properties.
    Nero InfoTool works too: www.cdspeed2000.com
    May 2003
    Canada
    device manager only tells me driver version not Firmware... But thanks for the link to the info tools.. It worked and I found out I have the latter firmware and no need to update.. thanks
    canada
    The quickest way to find out the firmware version is try and install the latest version firmware,it always tells you the firmware version you have before you update.
    The latest firmware is B6!
    AMD XP 2600+ Barton * ASUS A7N8X-X * 256 DDR pc3200 * Radeon 9000Pro 128mb * 280GB HD * WinXP Pro
  6. go to:
    -start menu
    -programs
    -accessories
    -system tools
    -system info
    -double click components
    -click once on cd-rom
    -look for your drive
    -look at PnP device id
    -the version is show between the -------------------??????-----------------
  7. Member SLICK RICK's Avatar
    Mar 2003
    Houston, Tx by way of N.O
    DVDInfo will give you alot of info about your drive (and whatever media you have in the drive).
    SLICK RICK
    Nobody likes a bunch of yackity-yack.
  8. Originally Posted by Neo2741 View Post
    go to:
    -start menu
    -programs
    -accessories
    -system tools
    -system info
    was quickest solution!
    Quicker: Checking display when PC is started- if too quick freeze with break-button when you see optical drive.
