My video is xvid and the sound is ac3, how do I convert this to play on my dvd player. Do I need to do anything to the sound, isn't ac3 what you want it to be so that it will work on the dvd player?
do you not see the words HOW To and under that CONVERT avi dv divx etc to vcd svcd dvd.... come on make a litte effort first to try to find the answer yourself and people will make a effort to try to help you....
Thanks for being so helpful. I have tried to do this 4 times and I get the same result. It won't play in the dvd player.
I'm assuming you have a set top DVD player ?Originally Posted by tekanded
You need to convert the XVid file to MPEG2 and then author it to convert it to IFO, BUP and VOB files. Then you will be able to watch it on your DVD Player. Theres a fair chance though that downloaded movies will look crap at DVD resolution though.If in doubt, Google it.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 15:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
