It seems everywhere I look , People say the Phillips 711 will play vcds just fine....But mine won't.
It registers as VCD....I put in the disc and it says VCD..play, then just stops.
It never leaves the inital Phillips (no disk, blue collage screen).
If i hit play, it trys then Stops.
My firmware is like 7.03...does it need updating, and if so..HOW do i do the upgrade? I saw a 7.22 Firmware file and downloaded it, but i dunno how to use it? Just burn the 2 files on a cdr and pop it in the dvd player??
Anyone able to tell me why this player wont play VCDs?
Are you making your own VCDs or are you testing your player with VCDs that are known to be good?
Do your VCDs work on any other player?
Also, does it say in your DVD manual that your player can explicitly play VCD AND read CD-R and CD-RW media?
Regards.
Michael Tam
w: Morsels of Evidence -
yes i am using a burned VCD, but it works on my PC and on a friends stand alone dvd player.
My player states right on the front DVD/VCD/cdr/cdrw
It plays DVD, CD-r , and CD-rw perfectly....only trouble is with VCD, which it recognises as VCD, but fails to play it. -
Okay, there may be a problem with the VCD itself...
How did you create it? Encoder? What method? What settings? How did you burn it?
Regards.
Michael Tam
i just borrowed it from a friend...he burned it, but it plays on his stand alone dvd player.
Hmmmm.....dunno what up
I upgraded to 7.12 firmware, but it still does the same thing -
guess i will try a store-bought VCD sometime before i deciede that this player is Pants.
It may be the way your friend encoded the disc. If he uses EasyCreator than the player may not able to play it. Tell him to use Nero and try again. I have a Philips dvd711.
Blu ray player (Phillips BDP2700/12) won't play some movies.
By lema1610 in forum Authoring (Blu-ray)Replies: 8Last Post: 12th Oct 2011, 08:48 -
downloaded video wont play in my dvd player
By KingRich70 in forum Newbie / General discussionsReplies: 17Last Post: 10th Jan 2011, 19:52 -
how to encode MPEG4 to play on a phillips DVP-642 player
By thejunkman12 in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2008, 09:32 -
DVD Player wont play DTS 6Ch, can i change Audio?
By snadge in forum Newbie / General discussionsReplies: 31Last Post: 16th Jan 2008, 07:12 -
Ive copied a avi disc but it wont play on my dvd player
By popeye39 in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2007, 16:26
