I created two titles on a DVD+R and inserted chapters
myself......then i finalized the disc. The disc plays in all 3 of
my dvd players but the chapters i created don't show up in ANY of
them. (i can't use the chapter skip...i can only search thru the disc)
I used a MEMOREX DVD+R which is one of the supported dvd+Rs for this
recorder.
When I create chapters on a DVD+RW the chapter skips work just fine.
Why arent my chapters (edits) being finalized so my other players
reckognize them? (of course, i put the disc back in the CH1500 and
it reckognized them just fine!)
This is a universal problem applied to all DVD+R discs.
from the following link:Likewise, you cannot add chapter stops in a recording, as this also requires a change in the video stream. However, if the recorders offers this functionality, you can add chapters in a DVD+R recording afterwards, but these can not be made DVD-Video compatible. You can only access them when the disc is played on the recorder, and hence they should be considered as a convenience feature.
http://www.dvdplusrw.org/Article.asp?mid=8&sid=11&aid=15
One way to circumvent this problem is to select the "Auto Chapter On" option which will create chapter for each 5-minute segment. -
So if I let the player create the chapters on a DVD+R (every 5 minutes) THOSE will work on a regular dvd player ?
And what about the other edits I make (hidden chapters, etc) do those also not transfer to a regular Dvd player?
if this is the case, i'm going to be buying DVD+RW from now on...I don't see the point of even using a write once option with this recorder.
Cyberhome AD-L 528 Crashes with DVD+R
By christaltips in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th Dec 2011, 07:54 -
DENON DVD-1500 does not play any discs...
By jOlDMaN in forum DVD & Blu-ray PlayersReplies: 5Last Post: 7th Jan 2011, 06:18 -
CyberHome DVD Recorder
By JRPAT in forum DVD & Blu-ray RecordersReplies: 1Last Post: 25th Sep 2008, 19:08 -
Cyberhome 400 DVD Player
By 67runes in forum DVD & Blu-ray PlayersReplies: 2Last Post: 26th Dec 2007, 14:59 -
Looking for replacement for Cyberhome CH-DVD 300
By inmate1577 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 19th Dec 2007, 09:28
