I just had to perform a full system restore... after re-installing TmpgEnc 2.5, it will no longer convert my dv files to M2V+wav instead it makes m2v+mp2... I like the wav file because I can normalize it in Cool Edit and remaster the sound if need... could someone please help me with this problem? Thanks!!!
Results 1 to 9 of 9
under the audio tab in "setting" , select PCM instead of default mpeg audio
or select ES stream only for video and use File -> Output to file -> wav file
right here as in this pic
upgrade to the lastest version then as a suggestion ...
or use this method https://www.videohelp.com/forum/viewtopic.php?p=780547#780547
Thank you!!! I just downloaded the latest version of the software and it works fine...
I appreciate your help!
DV won't play correctly anymore.
By xtremeD63 in forum Software PlayingReplies: 52Last Post: 9th Apr 2011, 13:08 -
DV video clip won't play anymore
By cajustse in forum Newbie / General discussionsReplies: 3Last Post: 11th Jun 2009, 14:57 -
My player won't play burned discs anymore.
By uNderdog_101 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 30th Dec 2007, 16:44 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08 -
Help! My Dvd Player Won't Mp3's Anymore
By Just8 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 1st Jul 2007, 23:08
