I have a 16x DVD-Rom and i usually copy the dvd on to my comp in about 25-30 minutues...is this about right. Well at least it is better than yesterday before i reinstalled my IDE Channels cause it was taking 1 hour 15mins - 1 hour 45 mins
any help will be highly appreciated
also i have a lg 4040b and i have only been able to burn at 2x i think i updated to the newest firmware but i still have this problem... i figure that my blank dvds are just actually 2x POS's. is anyone still having the burning speed problem with the 4040b after the updated firmware
thnx
Results 1 to 9 of 9
With DVDs, I never rip/burn above 4x. Basically because Ive never had an error in doing so.
Sometimes it depends on the DVD being ripped, but generally it takes me 8-14 minutes to rip a 2 layer DVD.
Sounds like you didn't have DMA enabled when it was taking over an hour. Still might not be enabled if it's taking 25-30 minutes. -
Hey rilo321,
As for your concerns regarding ripping speed, check out the tips in this thread and see if they help: https://www.videohelp.com/forum/viewtopic.php?t=180270
Cheers,
DhruvI only dream in black & white...
MSN: paschendale@gmail.com -
actually i was unabel to update the firmware for my drive because i couldn't find anything for my drive...i have a starlogic platinum 16x dvd-rom if any has any ideas or knows any where that would have the firmware for that piece thatwould be awesome
16x is the maximum possible speed your drive is capable of ripping at when it gets to the very outside of a disc given perfect conditions in a vacuum
In reality, no DVD-ROM can rip at anywhere near this throughout the whole disc consistently with a variety of DVDs. I have not heard of the brand of your DVD-ROM so I don't know whether they're any good or not, but it might help to try a different DVD-ROM. I have a LiteOn and a Pioneer and they both are pretty good. I think it would be fair to say that you should average between 4x and 8x consistently. This translates roughly into between 10 and 20 minutes but there are other factors like the intensity of encryption that can slow your ripping speeds down.If in doubt, Google it. -
i think mine is like a branch of liteon but im not really sure i got it about a year ago and it was an average price like somewhere from 70-90 dollars so given that it might be liteon made does anyone have any suggestions on how to find the firmware for it
If it is a Lite-on, then this might be what you're after:
http://forum.rpc1.org/dl_firmware.php?category=1&manufactor=17
Movie speeds
By drmrsolds in forum Video ConversionReplies: 8Last Post: 16th Nov 2009, 07:35 -
Write Speeds - anything new?
By Mike99 in forum MediaReplies: 22Last Post: 10th Feb 2009, 20:41 -
Burning speeds
By Rogert in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2008, 08:28 -
Encoding speeds
By Illusionist in forum ComputerReplies: 13Last Post: 11th Jul 2008, 11:01 -
DVD Decrypter / DVD Fab - Extremely slow ripping speeds in Vista
By awp in forum DVD RippingReplies: 5Last Post: 19th Dec 2007, 14:11
